Hi there,
I’m trying to set up a Talos OS. In my configuration, there are a couple of servers with no DHCP. I’m configuring the network for Talos using the command line. Unfortunately, it is not possible to pass those variables to the OS section inside the VM Template. Is there a way to do so or implement it?
Here is an exaple of cmdline:
KERNEL_CMD = "talos.platform=nocloud slab_nomerge pti=on ip=10.20.30.40::10.20.30.1:255.255.255.0::eth0:off
So basically I’d like to replace hardcoded information with variables: $NIC[IP], $NIC[GATEWAY], $NIC[MASK] inside OS[KERNEL_CMD].
