some days ago for the first time I installed open nebula.
I would add a new datasource (“SAMSUNG SDD”). As I have mounted the ssd on /mnt/SSD.
FILE and IMAGE types seem work fine instead SYSTEM is not working (it is not initializate). Please see below:
and for this reason I cannot create a VM on new datasource.
Do someone know why?
Many thanks,
Best.
Danilo
Ubuntu 16.04, Open Nebula 5.4.1
Steps to reproduce: Mount another hard disk and add a new datasource
Can do a thing more easy?
Could you please explain the steps to add a datasource, for example a USB STORAGE or a SATA Hard disk, to a open nebula?
I have not found a documentation for this.
I have already done it several times. Same behaviour (Images and Files datastore recognized but SYSTEM datastore not).
Generally, What am I doing wrong?
Can you try creating the datastore through the CLI using the “onedatastore create” command? You’ll need to create a datastore template.
Since I cannot see the template of the datastore 134 I cannot really see what is wrong. Alternatively, please post the output of the following SQL command run against the DB:
