After reboot Sunstone won't start
Just rebooted a front end and now Sunstone won’t load, I have this error in the logs:
Any ideas ?
sunstone.error
/usr/lib/one/sunstone/models/sunstone_guac.rb:29: warning: already initialized constant VAR_LOCATION
/usr/lib/one/sunstone/sunstone-server.rb:24: warning: previous definition of VAR_LOCATION was here
== Sinatra (v2.1.0) has taken the stage on 80 for production with backup from Thin
== Sinatra has ended his set (crowd applauds)
/usr/share/one/gems-dist/gems/eventmachine-1.2.7/lib/eventmachine.rb:531:in `start_tcp_server': no acceptor (port is in use or requires root privileges) (RuntimeError)
	from /usr/share/one/gems-dist/gems/eventmachine-1.2.7/lib/eventmachine.rb:531:in `start_server'
	from /usr/share/one/gems-dist/gems/thin-1.8.0/lib/thin/backends/tcp_server.rb:16:in `connect'
	from /usr/share/one/gems-dist/gems/thin-1.8.0/lib/thin/backends/base.rb:65:in `block in start'
	from /usr/share/one/gems-dist/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:in `run_machine'
	from /usr/share/one/gems-dist/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:in `run'
	from /usr/share/one/gems-dist/gems/thin-1.8.0/lib/thin/backends/base.rb:75:in `start'
	from /usr/share/one/gems-dist/gems/thin-1.8.0/lib/thin/server.rb:162:in `start'
	from /usr/share/one/gems-dist/gems/rack-2.2.3/lib/rack/handler/thin.rb:22:in `run'
	from /usr/share/one/gems-dist/gems/sinatra-2.1.0/lib/sinatra/base.rb:1565:in `start_server'
	from /usr/share/one/gems-dist/gems/sinatra-2.1.0/lib/sinatra/base.rb:1499:in `run!'
	from /usr/lib/one/sunstone/sunstone-server.rb:1206:in `<main>'
Can you check who are already used the port?
There aren’t any processes using port 80. There is some kind of permissions issue. All of the installs we have done using miniONE have this issue intermittently / usually after reboot.
