Hi Find the requested logs…
Log> while creating VM from exported template from vcenter
Thu Nov 24 00:58:37 2016 [Z0][VM][I]: New state is ACTIVE
Thu Nov 24 00:58:37 2016 [Z0][VM][I]: New LCM state is PROLOG
Thu Nov 24 00:58:37 2016 [Z0][VM][I]: New LCM state is BOOT
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/3/deployment.0
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: Command execution fail: /var/lib/one/remotes/vmm/vcenter/deploy ‘/var/lib/one/vms/3/deployment.0’ ‘ESX-CLS’ 3 ESX-CLS
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: /usr/lib/one/ruby/vendors/rbvmomi/lib/rbvmomi/type_loader.rb:66: warning: already initialized constant RbVmomi::VIM::Datastore
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: /usr/lib/one/ruby/vcenter_driver.rb:51: warning: previous definition of Datastore was here
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: Deploy of VM 3 on host ESX-CLS with /var/lib/one/vms/3/deployment.0 failed due to "Cannot clone VM Template: InvalidArgument: A specified parameter was not correct: "
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: ExitCode: 255
Thu Nov 24 00:58:37 2016 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Thu Nov 24 00:58:37 2016 [Z0][VMM][E]: Error deploying virtual machine
Thu Nov 24 00:58:37 2016 [Z0][VM][I]: New LCM state is BOOT_FAILURE
[root@one-sandbox ~]# onetemplate show 1
TEMPLATE 1 INFORMATION
NAME : ESX - 192.168.1.70
USER : oneadmin
GROUP : oneadmin
REGISTER TIME : 11/23 21:30:26
OWNER : um-
GROUP : um-
OTHER : um-
TEMPLATE CONTENTS
CPU=".2"
DESCRIPTION="vCenter Template imported by OpenNebula from Cluster 192.168.1.70"
HYPERVISOR="vcenter"
KEEP_DISKS_ON_DONE="NO"
LOGO="images/logos/linux.png"
MEMORY="1024"
PUBLIC_CLOUD=[
TYPE=“vcenter”,
VM_TEMPLATE=“564d9103-04ed-7622-71f3-12725a153d5d” ]
SCHED_REQUIREMENTS="ID="4""
VCENTER_DATASTORE=“datastoredisk”
root@one-sandbox ~]# onevm show 0
VIRTUAL MACHINE 0 INFORMATION
USER : oneadmin
GROUP : oneadmin
STATE : ACTIVE
LCM_STATE : BOOT_FAILURE
RESCHED : No
HOST : ESX-CLS
CLUSTER ID : 0
CLUSTER : default
START TIME : 11/24 00:36:57
END TIME : -
DEPLOY ID : -
VIRTUAL MACHINE MONITORING
OWNER : um-
GROUP : —
OTHER : —
VM DISKS
ID DATASTORE TARGET IMAGE SIZE TYPE SAVE
0 - hda CONTEXT -/- - -
VIRTUAL MACHINE HISTORY
SEQ HOST ACTION DS START TIME PROLOG
0 ESX-CLS none -1 11/24 00:37:12 0d 00h30m 0h00m00s
USER TEMPLATE
PUBLIC_CLOUD=[
TYPE=“vcenter”,
SCHED_REQUIREMENTS="NAME="192.168.1.70""
VIRTUAL MACHINE TEMPLATE
AUTOMATIC_REQUIREMENTS="!(PUBLIC_CLOUD = YES) | (PUBLIC_CLOUD = YES & (HYPERVISOR = vcenter))“
CONTEXT=[
DISK_ID=“0”,
NETWORK=“YES”,
SSH_PUBLIC_KEY=”",
TARGET=“hda” ]
CPU="0.2"
GRAPHICS=[
LISTEN=“0.0.0.0”,
PORT=“5900”,
TYPE=“VNC” ]
MEMORY="1024"
TEMPLATE_ID="1"
VMID=“0”
Again while exporting vcenter datastore it says no new data store to export… not sure why
[root@one-sandbox ~]# onevcenter datastores --vcenter 192.168.1.30 --vuser oneadmin@vsphere.local --vpass Test@123user
Connecting to vCenter: 192.168.1.30…done!
Looking for Datastores…done!
Do you want to process datacenter Pri-DC-1 [y/n]? y
No new Datastores found in Pri-DC-1…
[root@one-sandbox ~]# onehost show 4
HOST 4 INFORMATION
CLUSTER : default
STATE : MONITORED
IM_MAD : vcenter
VM_MAD : vcenter
LAST MONITORING TIME : 11/24 01:03:56
HOST SHARES
TOTAL MEM : 0K
USED MEM (REAL) : 0K
USED MEM (ALLOCATED) : 4G
TOTAL CPU : 0
USED CPU (REAL) : 0
USED CPU (ALLOCATED) : 80
RUNNING VMS : 4
MONITORING INFORMATION
AVAILHOST="0"
CPUSPEED="NaN"
IM_MAD="vcenter"
PUBLIC_CLOUD=“YES"
RESERVED_CPU=”“
RESERVED_MEM=”"
TOTALHOST="0"
VCENTER_DATASTORE="datastore"
VCENTER_DATASTORE="datastoredisk"
VCENTER_DATASTORE="usbds"
VCENTER_HOST="192.168.1.30"
VCENTER_PASSWORD="4Tv2RXBGzYGdZSwLZVgKOw=="
VCENTER_USER="oneadmin@vsphere.local"
VM_MAD=“vcenter”
WILD VIRTUAL MACHINES
NAME IMPORT_ID CPU MEM ORY
VIRTUAL MACHINES
0 oneadmin oneadmin 1 fail 0 0K ESX-CLS 0d 00h27
1 oneadmin oneadmin 2 fail 0 0K ESX-CLS 0d 00h17
2 oneadmin oneadmin 3 fail 0 0K ESX-CLS 0d 00h15
3 oneadmin oneadmin 5 fail 0 0K ESX-CLS 0d 00h06
[root@one-sandbox ~]# onedatastore list
0 system - - 0 0 sys - ssh on
1 default 9.1G 78% 0 1 img fs ssh on
2 files 9.1G 78% 0 0 fil fs ssh on
100 datastore 0M - 100 0 img vmfs vmfs on
101 datastoredisk 9.1G 78% 100 0 img fs shared on
[root@one-sandbox ~]# onedatastore show 100
DATASTORE 100 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 100
TYPE : IMAGE
DS_MAD : vmfs
TM_MAD : vmfs
BASE PATH : /vmfs/volumes/100
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 0M
FREE: : 0M
USED: : 0M
LIMIT: : -
OWNER : um-
GROUP : u–
OTHER : —
DATASTORE TEMPLATE
BRIDGE_LIST="192.168.1.30"
CLONE_TARGET="SYSTEM"
DS_MAD="vmfs"
LN_TARGET="NONE"
TM_MAD="vmfs"
TYPE=“IMAGE_DS”
IMAGES
IMAGES
[root@one-sandbox ~]# onedatastore show 101
DATASTORE 101 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 100
TYPE : IMAGE
DS_MAD : fs
TM_MAD : shared
BASE PATH : /vmfs/volumes/101
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 9.1G
FREE: : 7.1G
USED: : 1.5G
LIMIT: : 19.5G
OWNER : um-
GROUP : um-
OTHER : um-
DATASTORE TEMPLATE
DISK_TYPE="FILE"
DS_MAD="fs"
LIMIT_MB="20000"
LN_TARGET=“NONE"
RESTRICTED_DIRS=”/“
SAFE_DIRS=”/var/tmp"
TM_MAD="shared"
TYPE=“IMAGE_DS”
