This is a general question and affects version 5.4.1. I think older versions don’t have a solution for this too.
I have created several VMs. Now I want to alter the configuration. For example I want to limit the IOPS of one specific VM disk? I cannot find a way to handle this as I cannot alter the applied template comfiguration.
Is there a way to alter the configuration after a VM is created?
Yeah I also thought about this. This is the only possibility in my eyes currently. But what about a VM with volatile disks attached to it. In this case I cannot save them.
I would be interested what the Opennebula team thinks about this? @ruben@jfontan@tinova what do you think about this? Is there a way to alter the VM configuration after deployment?
With OpenNebula 5.4 you can change the VM metadata using onevm change body vm --id <VMID> but you should still need to run an operation that re-creates the VM deployment file like undeploy and then resume.
For example to change TOTAL_BYTES_SEC to ‘2048’ for disk with ID 3 in VM with ID 123:
onedb change-body vm --id 123 '/VM/TEMPLATE/DISK[DISK_ID=3]/TOTAL_BYTES_SEC/' 2048
Please note that AFAIK currently with this interface you can only alter and delete already available attributes but it it is not possible to add new ones(#5448), also it is working only for VMs owned by oneadmin (#5443).
