Apache as reverse proxy for Sunstone.....but no_vnc?
I have a separate apache server that i’m using to reverse in https the opennebula FE;
all work well, but when i try to open vm consoles under novnc or spice, nothing appear.
ATM the apache server configuration reverse proxying OpennebulaFE is:
<VirtualHost 192.168.1.40:443>
ServerName myserver
ProxyPreserveHost Off
RewriteEngine on
RewriteRule ^(.*)+(nebula)$ %{REQUEST_URI}/ [R=301,L]
SSLEngine on
SSLCertificateFile /etc/pki/certs/xxxx.crt
SSLCertificateKeyFile /etc/pki/private/xxxxx.key
SSLCertificateChainFile /etc/pki/certs/xxxxxxxx.pem
<Location /nebula>
ProxyPass http://192.168.1.202:9869
ProxyPassReverse http://192.168.1.202:9869
I read about ws://xxxxx/:29876 websockify settings… but nothing worked for me.
servers:
(192.168.1.40 - apache reverseproxy)—
(192.168.1.202 - opennebulaFE -sunstone)—
(192.168.1.201 - opennebula node kvm-hypervisor)
Any ideas ??
Thanks
Igor
Dirty trick.
Set a persistent ssh tunneled port from your Apache proxy to your sunstone
Set this in autostart eventually in a screen session at startup
autossh -f -M 0 -N -i /path/to/youruser/id_rsa -o ExitOnForwardFailure=yes -o ServerAliveInterval=30 -o ServerAliveCountMax=3 -L 29876:localhost:29876 user@yoursunstoneserver
And your vnc will work.
autossh will keep the tunnel up even in network loss
Cheers
If someone has better suggestions those are welcome, tried (not hard, but lazily) to proxy the websocket of the vncproxy with nginx but did not managed to get it working (yet).
So I’m still using autossh tunnel since is working fine for my needs, not elegant but working.
Grazie !! Thank you Lorenzo…i will try this workaround waiting a solution for ProxyPass.
Bye
What about this?
http://nginx.org/en/docs/http/websocket.html
