Hi All,
I have configured reverse proxy through nginx so as to access Sunstone UI with HTTPs.
Below is my nginx config:
# No squealing.
server_tokens off;
# OpenNebula Sunstone upstream
upstream sunstone {
server 127.0.0.1:9869;
# OpenNebula websocketproxy upstream
upstream websocketproxy {
server 127.0.0.1:29876;
# OpenNebula FireEdge
upstream fireedge {
server 127.0.0.1:2616;
# HTTP virtual host, redirect to HTTPS
server {
listen 80 default_server;
return 301 https://$host$request_uri;
# Example Sunstone configuration (/etc/one/sunstone-server.conf)
#:vnc_proxy_port: 127.0.0.1:29876
#:vnc_proxy_support_wss: only
#:vnc_proxy_cert: /etc/ssl/certs/one-selfsigned.crt
#:vnc_proxy_key: /etc/ssl/private/one-selfsigned.key
#:vnc_proxy_ipv6: false
#:vnc_request_password: false
#:vnc_client_port: 443
# HTTPS virtual host, proxy to Sunstone
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name frontend;
root /usr/share/nginx/html;
access_log /var/log/nginx/opennebula-sunstone-access.log;
error_log /var/log/nginx/opennebula-sunstone-error.log;
client_max_body_size 1G;
error_page 404 /404.html;
location = /40x.html {
error_page 500 502 503 504 /50x.html;
location = /50x.html {
location / {
# Handle inconsistency in the websockify URLs provided by Sunstone
if ($args ~* "host=.+&port=.+&token=.+&encrypt=.*") {
rewrite ^/$ /websockify/ last;
proxy_pass http://sunstone;
proxy_redirect off;
log_not_found off;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-FOR $proxy_add_x_forwarded_for;
location /websockify {
proxy_http_version 1.1;
proxy_pass https://websocketproxy;
proxy_read_timeout 61s;
proxy_buffering off;
ssl_certificate /etc/ssl/certs/one-selfsigned.crt;
ssl_certificate_key /etc/ssl/private/one-selfsigned.key;
ssl_stapling on;
## OpenNebula XML-RPC proxy (optional)
upstream onexmlrpc {
server 127.0.0.1:2633;
upstream vncxmlrpc {
server 127.0.0.1:2644;
server {
listen 2634 ssl;
listen [::]:2634 ssl;
location / {
proxy_pass http://onexmlrpc;
proxy_read_timeout 180s;
location /RPC2/vnctoken {
proxy_pass http://vncxmlrpc;
ssl_stapling on;
# FireEdge
server {
listen 2646 ssl;
listen [::]:2646 ssl;
location / {
proxy_pass http://fireedge;
All seem functional except the SPICE console which is not working.
I have made the appropriate changes at /etc/one/sunstone-server.conf as below:
:allow_vnc_federation: no
:public_fireedge_endpoint: https://x.x.x.x:2646
When I access VNC through guacamole seems fine. When I try SPICE console access at a VM that has SPICE enabled at its config, I get an empty grey screen. The console connection is not progressing and the browser seems to be trying to access https://x.x.x.x/spice?socket=d3NzO... where x.x.x.x is the public IP of the Opennebula server/frontend.
I have not been able to figure out where the issue lies.
Any idea or working example with nginx?
Thank you very much
Alex
– Details
Opennebula: 6.8.0 CE
Host: KVM
Guest VMs: Windows11, Debian12.
