API and python bindings (pyone)
Hello!
I’m trying to create VM or VM template with several disks using pyone lib, but it looks like there is an issue or something.
Here is a code sample I use:
#!/usr/bin/python
     import pyone
     one = pyone.OneServer("http://10.10.10.100:2633/RPC2", session="oneadmin:oneadmin")
     one.template.allocate(
         'TEMPLATE': {
           'NAME': 'test100',
           'MEMORY': '1024',
           'DISK': { 'IMAGE_ID': '314'},
           'DISK': { 'IMAGE_ID': '310'},
           'CPU' : '1',
           'VCPU' : '2'
When I run it, ONE creates the template with only one disk - the last one I specified.
Here is the result template:
CPU = “1”
DISK = [
IMAGE_ID = “310” ]
MEMORY = “1024”
VCPU = “2”
Any ideas why is that? Maybe I made a mistake in template description?
Thanks a lot!
Yes, this is a limitation. If there are duplicate entries in the template you need to pass it in ONE template format already, like this:
one.template.allocate('''
  NAME="test100"
  MEMORY="1024"
  DISK=[ IMAGE_ID= "314"]
  DISK=[ IMAGE_ID= "310"]
  CPU="1"
  VCPU="2"
Thanks a lot, It works now.
Is the information about limitation anywhere in documentation?
Thanks!
