My objective is to be able to change the hostname of the EC2 instance to that defined in OpenNebula.
I am trying to use cloud-init and I have managed to pass static user-data to the instance, but I cant see how to send any other data e.g. vm name.
Anyone know if OpenNebula, EC2 and Colud-init can work?
I have tried setting a Tag in the template, but it seems to be broken.
I set the tag to “Name = fred” and on the instance i get a tag with Key = “-t” and Value = "Name fred"
Any one else seen this? is it a bug or am i setting it wrong?
I have looked at using OneGate so that I can pull the data from OpenNebula. I have enabled “Add OneGate Token” and in the instance Tags can see the tag ONE_ID, but can not see how to get the token.txt data visible in the VM.
Any idea how to get token.txt on the instance?
Regards
Adrian
