Ec2 with a opennebula ESXi
is possible to access to mi amazon ec2 account if i have a Esxi opennebula configuration?
I folllow this guide and now i would like to connect to my ec2 instances
http://docs.opennebula.org/4.10/design_and_installation/quick_starts/qs_centos_vmware.html#qs-centos-vmware
how i do to create a instance in amazon since my opennebula sunstone?
Thanks
Yes, it is entirely doable, please follow the guide of the Amazon EC2 driver to configure and enable this functionality.
-Tino
hi, thanks i already create the Amazon ec2 host and now when i try to create a template and instantiate a VM the VM keep in pending.
This is my template:
SCHED_REQUIREMENTS="ID="1""
CPU=“1"
SUNSTONE_CAPACITY_SELECT=“YES"
CONTEXT=[SSH_PUBLIC_KEY=”$USER[SSH_PUBLIC_KEY]”,NETWORK=“YES”]
MEMORY="613"
EC2=[INSTANCETYPE=“t1.micro”,AMI=“ami-17c44860”,KEYPAIR=“nebula1”]
SUNSTONE_NETWORK_SELECT=“YES”
questions:
The ami has to be to my property ?
because i use a public template from amazon
something is missing in my template?
Thanks
Could you share the output of “onehost list”?
The template seems to be fine. The ami needs to be accessible by you (either of your property or public)
0 172.16.36.110 - 1 100 / 400 (25%) 512M / 8G (6%) on
1 ec2 - 0 0 / 500 (0%) - on
Othe question, the key pairs has to be the Cloud Front key pairs from my security credentials or the key pairs from my ec2 dashboard ?
Thanks
There seems to be a problem with the memory capacity of the ec2 host, check your ec2_driver.conf configuration. That is why the VMs are in pending (you can force the deployment however, to check that the driver is working properly)
Regarding the keypairs, you need to use the ones from your ec2 dashboard.
-Tino
thanks i already solved my issue thanks a lot :slight_smile:
