AWS provisions have stopped working
Without any change on my part, either in my code or in OpenNebula the AWS provisions have stopped working. So i’m guessing it has something to do with either terraform or ansible.
I’m getting this error when provisioning from either CLI or FireEdge, I’ve tried different providers on different AWS zones with the same result
WARNING: This operation can take tens of minutes. Please be patient.
- Waiting until host(s) are ready in OpenNebula
ERROR: Failed to configure hosts
- 3.71.16.23 : TASK[Install libselinux-python3 (Centos8 8)] - non-zero return code
- 18.192.49.157 : TASK[Install libselinux-python3 (Centos8 8)] - non-zero return code
1. quit
2. retry
3. skip
4. cleanupe
Also tried removing the providers and following the tutorial, but i’m getting the same error Provisioning an Edge Cluster — OpenNebula 6.2.0 documentation
I’m using OpenNebula 6.2 CE
a more detailed log is below, seems like ansible can’t install linux dependencies
detailed log, fail at the end
Executing command: create
2022-02-02 10:32:49 +0000
Command options: batch debug [json, true] [user, serveradmin:oneadmin] [password…
Creating provision objects
Creating OpenNebula cluster: ${provision}
Cluster created with ID: 173
Creating datastore ${provision}-image
2022-02-02 10:32:50 +0000
datastore created with ID: 246
Creating datastore ${provision}-system
datastore created with ID: 247
Creating network ${provision}-public
2022-02-02 10:32:51 +0000
network created with ID: 73
Creating OpenNebula host: provision-5e830b79ed9282688ae1c99af6509bc70ce819cae381…
host created with ID: 240
2022-02-02 10:32:52 +0000
Deploying
Command run: terraform version --json
Command STDOUT: { “terraform_version”: “0.14.7”, “terraform_revision”: “”, …
Command succeeded
Command run: cd /tmp/tf20220202-8551-txls9h; terraform 0.13upgrade -yes
2022-02-02 10:32:53 +0000
Command STDOUT: The 0.13upgrade command has been removed. You must run this comm…
Command succeeded
Command run: cd /tmp/tf20220202-8551-txls9h; terraform init
2022-02-02 10:32:56 +0000
Command STDOUT: Initializing the backend… Initializing pr…
Command succeeded
Command run: cd /tmp/tf20220202-8551-txls9h; export TF_LOG=DEBUG; terraform appl…
2022-02-02 10:33:55 +0000
Command STDOUT: aws_vpc.device_173: Creating… aws_vpc.device_173: Creation complete after 1s [id=vpc-08d8eeeeec5ca5e0d] aws_subnet.device_173: Creating… aws_internet_gateway.device_173: Creating… aws_security_group.device_173_all: Creating… aws_internet_gateway.device_173: Creation complete after 1s [id=igw-0ed3a0bdba512f09d] aws_route.device_173: Creating… aws_route.device_173: Creation complete after 0s [id=r-rtb-06feb7e13cb0648bb1080289494] aws_security_group.device_173_all: Creation complete after 3s [id=sg-0dc91292750db29b6] aws_subnet.device_173: Still creating… [10s elapsed] aws_subnet.device_173: Creation complete after 11s [id=subnet-06362b8a76415af47] aws_instance.device_240: Creating… aws_instance.device_240: Still creating… [10s elapsed] aws_instance.device_240: Still creating… [20s elapsed] aws_instance.device_240: Still creating… [30s elapsed] aws_instance.device_240: Still creating… [40s elapsed] aws_instance.device_240: Creation complete after 42s [id=i-0be25dc1fd96243e4] Warning: Interpolation-only expressions are deprecated on deploy.tf line 83, in data “aws_ec2_instance_type_offerings” “available”: 83: values = ["${each.key}"] Terraform 0.11 and earlier required all non-constant expressions to be provided via interpolation syntax, but this pattern is now deprecated. To silence this warning, remove the “${ sequence from the start and the }” sequence from the end of this expression, leaving just the inner expression. Template interpolation syntax is still used to construct strings from expressions when the template includes multiple interpolation sequences or a mixture of literal strings and interpolations. This deprecation applies only to templates that consist entirely of a single interpolation sequence. Apply complete! Resources: 6 added, 0 changed, 0 destroyed. Outputs: device_id_240 = “i-0be25dc1fd96243e4” ip_240 = “18.170.218.85”
Command STDERR: 2022/02/02 10:32:56 [WARN] Log levels other than TRACE are curre…
Command succeeded
Command run: cd /tmp/tf20220202-8551-txls9h; terraform output
2022-02-02 10:33:56 +0000
Command STDOUT: device_id_240 = “i-0be25dc1fd96243e4” ip_240 = “18.170.218.85”
Command succeeded
Monitoring hosts
Generating Ansible configurations into /tmp/d20220202-8551-wilnbj
Creating /tmp/d20220202-8551-wilnbj/inventory: [nodes] 18.170.218.85 [targets] 18.170.218.85 ansible_connection=ssh ansible_ssh_private_key_file=/var/lib/one/.ssh-oneprovision/id_rsa ansible_user=centos ansible_port=22
Creating /tmp/d20220202-8551-wilnbj/group_vars.yml: — sys_ds_ids: - 247 first_host: 18.170.218.85
Creating /tmp/d20220202-8551-wilnbj/host_vars/18.170.218.85.yml: — oneprovision_hypervisor: qemu opennebula_ssh_deploy_private_key: true opennebula_node_kvm_use_ev: true opennebula_node_kvm_param_nested: true opennebula_node_kvm_manage_kvm: false
Creating /tmp/d20220202-8551-wilnbj/ansible.cfg: [defaults] retry_files_enabled = False deprecation_warnings = False display_skipped_hosts = False callback_whitelist = stdout_callback = skippy host_key_checking = False roles_path = /usr/share/one/oneprovision/ansible/roles [privilege_escalation] become = yes become_user = root
Checking working SSH connection
Command run: ANSIBLE_CONFIG=/tmp/d20220202-8551-wilnbj/ansible.cfg ANSIBLE_BECOM…
2022-02-02 10:34:07 +0000
Command STDOUT: 18.170.218.85 | UNREACHABLE! => { “changed”: false, "msg…
Command STDERR: [WARNING]: Skipping callback plugin ‘’, unable to load
Command FAILED (code=4): ANSIBLE_CONFIG=/tmp/d20220202-8551-wilnbj/ansible.cfg A…
2022-02-02 10:34:27 +0000
2022-02-02 10:34:28 +0000
2022-02-02 10:34:48 +0000
2022-02-02 10:35:08 +0000
2022-02-02 10:35:19 +0000
2022-02-02 10:35:39 +0000
2022-02-02 10:35:42 +0000
Command STDOUT: 18.170.218.85 | CHANGED | rc=0 >> Warning: Permanently added '18…
Command succeeded
Configuring hosts
Command run: ANSIBLE_CONFIG=/tmp/d20220202-8551-wilnbj/ansible.cfg ansible-playb…
2022-02-02 10:35:51 +0000
Command STDOUT: PLAY [all] *****************************************************…
Command FAILED (code=2): ANSIBLE_CONFIG=/tmp/d20220202-8551-wilnbj/ansible.cfg ansible-playbook --ssh-common-args=’-o UserKnownHostsFile=/dev/null’ -i /tmp/d20220202-8551-wilnbj/inventory -e @/tmp/d20220202-8551-wilnbj/group_vars.yml /usr/share/one/oneprovision/ansible/aws.yml
  • 18.170.218.85 : TASK[Install libselinux-python3 (Centos8 8)] - non-zero return…
Hello @Samu,
The provision is based on CentOS which is EOL. We have switched it to ubuntu2004 so the next OpenNebula release will come with it.
Best,
Álex.
Thanks @ahuertas
How could I make the switch before the next release is publised? I’m guessing I would have to change the provision AMI and adapt the ansible playbook to the new OS
Hello @Samu,
Yes the default AMI needs to be changed, but also another changes are needed, so I would recommend you to wait until the version is out.
Best,
Álex.
