Oneprovision is failing to create provisions, in different providers and different hypervisors
I’m not sure if this is a global problem or just mine. I accidentaly run sudo oneprovision once and since then I can’t create more provisions, even without sudo.
The problem is in the ansible TASK: Update local known_hosts
Log
WARNING: This operation can take tens of minutes. Please be patient.[WARNING]: Skipping callback plugin ‘’, unable to load
PLAY [all] *********************************************************************
TASK [python : Install Python 2 (Debian/Ubuntu)] *******************************
changed: [18.170.31.108]
TASK [Install libselinux-python3 (Centos8 8)] **********************************
PLAY [nodes] *******************************************************************
TASK [Gathering Facts] *********************************************************
ok: [18.170.31.108]
TASK [ddc : Check supported platform] ******************************************
ok: [18.170.31.108] => {
“changed”: false,
“msg”: “All assertions passed”
TASK [ddc : Disable ufw] *******************************************************
TASK [opennebula-repository : Install apt-transport-https] *********************
TASK [opennebula-repository : Add repository key] ******************************
TASK [opennebula-repository : Add OpenNebula repository (Ubuntu)] **************
TASK [opennebula-node-lxc : Install OpenNebula node LXC package] ***************
[WARNING]: The value 9869 (type int) in a string field was converted to ‘9869’
(type string). If this does not look like what you expect, quote the entire
value to ensure it does not change.
TASK [opennebula-ssh : Create /var/lib/one/.ssh directory] *********************
ok: [18.170.31.108]
TASK [opennebula-ssh : Configure SSH server PasswordAuthentication] ************
ok: [18.170.31.108]
TASK [opennebula-ssh : Configure SSH server PermitRootLogin] *******************
TASK [opennebula-ssh : Update local known_hosts] *******************************
failed: [18.170.31.108 → localhost] (item={‘type’: ‘ssh-rsa’, ‘key’: ‘hidden key=’}) => {“ansible_loop_var”: “item”, “changed”: false, “item”: {“key”: “hidden key=”, “type”: “ssh-rsa”}, “msg”: “ssh-keygen failed (rc=255, stdout=’’,stderr=‘do_known_hosts: hostkeys_foreach failed: Permission denied\r\n’)”}
failed: [18.170.31.108 → localhost] (item={‘type’: ‘ecdsa-sha2-nistp256’, ‘key’: ‘hidden key=’}) => {“ansible_loop_var”: “item”, “changed”: false, “item”: {“key”: “hiddden key”}, “msg”: “ssh-keygen failed (rc=255, stdout=’’,stderr=‘do_known_hosts: hostkeys_foreach failed: Permission denied\r\n’)”}
failed: [18.170.31.108 → localhost] (item={‘type’: ‘ssh-ed25519’, ‘key’: ‘hidden key’}) => {“ansible_loop_var”: “item”, “changed”: false, “item”: {“key”: “hidden key”, “type”: “ssh-ed25519”}, “msg”: “ssh-keygen failed (rc=255, stdout=’’,stderr=‘do_known_hosts: hostkeys_foreach failed: Permission denied\r\n’)”}
PLAY RECAP *********************************************************************
18.170.31.108 : ok=12 changed=8 unreachable=0 failed=1 skipped=35 rescued=0 ignored=0
This is happening in OpenNebula 6.2.1, in an Ubuntu 18.04 frontend and started happenining on the 17/03
