Bridge with Security not working?
I cannot get bridge with security to work. However a standard bridge works fine…
If I set vn_mad to fw no traffic can get through. e.g. ping google.com. However if it is set to bridge it works fine.
I have OpenNebula running on Ubuntu Server 20.04
My netplan is:
network:
  ethernets:
    eno2:
      dhcp4: false
  version: 2
  bridges:
    eno2br:
      dhcp4: yes
      interfaces:
        - eno2
      addresses: [192.168.1.2/24]
      gateway4: 192.168.1.254
      nameservers:
        addresses:
        - 8.8.8.8
public bridge network template with security (not working)
BRIDGE = "eno2br"
BRIDGE_TYPE = "linux"
DNS = "8.8.8.8, 8.8.4.4"
GATEWAY = "192.168.1.254"
NETWORK_ADDRESS = "192.168.1.2"
NETWORK_MASK = "255.255.255.0"
OUTER_VLAN_ID = ""
PHYDEV = ""
SECURITY_GROUPS = "0"
VLAN_ID = ""
VN_MAD = "fw"
Default security template
RULE = [
  PROTOCOL = "TCP",
  RULE_TYPE = "inbound" ]
RULE = [
  PROTOCOL = "TCP",
  RULE_TYPE = "outbound" ]
However this template does work
BRIDGE = "eno2br"
OUTER_VLAN_ID = ""
PHYDEV = ""
VLAN_ID = ""
VN_MAD = "bridge"
Any advise on what may be wrong would be greatly appreciated.
Hi @Daryn_L ,
Take a look at this. In your case, the private network is 192.168.1.0/24.
Cheers.
Hi @rdiaz,
Thanks for your reply.
Following your answer allows my VM to ping google. However the security groups do not work. e.g. if I delete both rules in the default group I can still ping google from within the VM.
Furthermore, my VM cannot ping other VMs either.
I have decided to try and go through the minione setup again. Maybe there is some step missing…
Here are the exact (and only) steps I have done:
  1. Fresh install ubuntu server 20.04 with openssh installed
  2. Modified my netplan to set a static IP to my router
network:
  version: 2
  ethernets:
    eno1:
      dhcp4: no
      addresses:
        - 192.168.1.100/24
      nameservers:
          addresses: [8.8.8.8, 8.8.4.4]
  1. update, upgrade and reboot
  2. sudo -s && cd
    ufw allow 80/tcp
    ufw allow 22/tcp
    ufw allow 2616/tcp
  3. wget ‘https://github.com/OpenNebula/minione/releases/latest/download/minione
  4. bash minione
### Main deployment steps:
Install OpenNebula frontend version 6.2
Install Terraform
Install Docker
Configure bridge minionebr with IP 172.16.100.1/24
Enable NAT over eno1
Modify AppArmor
Install OpenNebula KVM node
Export appliance and update VM template
Install  augeas-tools bridge-utils apt-transport-https iptables-persistent netfilter-persistent python3-pip unzip
Install pip 'ansible==2.9.9'
Everything ran OK
  1. login sunstone
  2. instantiate 2x instances of centos 7
  3. Test ping:
    instances can ping each other (172.16.100.3 from 172.16.100.2)
    instances can ping google.com
  4. network → security groups → default
    delete both default rules and update and commit
    onehost sync -f
  5. Test ping:
    can ping google.com (would presume I shouldn’t be able to?)
    cannot ping other vm (seems correct)
  6. network → security groups → default
    recreate both default ANY rules and update and commit
    onehost sync -f
  7. Test ping:
    can ping google.com
    cannot ping other vm (this should now work again?) (172.16.100.3 from 172.16.100.2)
  8. As per your suggestion
    as root:
    iptables -t nat -A POSTROUTING -s 172.16.100.0/24 ! -d 172.16.100.0/24 -j MASQUERADE
  9. Test ping:
    can ping google.com
    cannot ping other vm (172.16.100.3 from 172.16.100.2)
  10. delete VMs
  11. create 2x new VMs the same
  12. Test ping:
    can ping google.com
As soon as I make a change to the security group in sunstone it basically breaks all communication between VMs. Security groups are also not working still…
  1. reboot
  2. Test ping:
    can ping google.com
So basically, for me, tampering with the security groups breaks the whole system.
Any thoughts?
Best,
Daryn
