DNS issue resolved. I wrongly entered DNS context comma separated. Can I use firewall other than iptables in kvm hypervisor host ?
As I understand opennebula uses iptables rules to route vm traffic so I can not use firewalld or ufw in kvm hypervisor node. Is this true? I solved issue with disabling firewalld in ubuntu kvm node hypervisor. Now I can ssh virtual machines but I could not resolve DNS from vm. Are there any recommendation for this.
Regards
We installed opennebula frontend and kvm node in ubuntu 18.04. I created 8021q network for kvm hyperviser . VM take ip but does not reach outside of network. I suspect that is a routing issue in hypervisor besause there is no route fro one-11 virtual interface . My kvm hypervisor network ip addr output is like below.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp3s0f0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether b4:99:ba:b5:e0:f6 brd ff:ff:ff:ff:ff:ff
3: enp3s0f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether b4:99:ba:b5:e0:f8 brd ff:ff:ff:ff:ff:ff
inet6 fe80::b699:baff:feb5:e0f8/64 scope link
4: enp4s0f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether b4:99:ba:b5:e0:fa brd ff:ff:ff:ff:ff:ff
inet 10.11.3.155/16 brd 10.11.255.255 scope global enp4s0f0
inet6 fe80::b699:baff:feb5:e0fa/64 scope link
5: enp4s0f1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether b4:99:ba:b5:e0:fc brd ff:ff:ff:ff:ff:ff
6: br11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.11.3.164/16 brd 10.11.255.255 scope global dynamic br11
valid_lft 604745sec preferred_lft 604745sec
7: enp3s0f1.11@enp3s0f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br11 state UP group default qlen 1000
ip route
default via 10.11.0.1 dev enp4s0f0 proto static
default via 10.11.0.1 dev br11 proto dhcp src 10.11.3.164 metric 400
10.11.0.0/16 dev enp4s0f0 proto kernel scope link src 10.11.3.155
10.11.0.0/16 dev br11 proto kernel scope link src 10.11.3.164
10.11.0.1 dev br11 proto dhcp scope link src 10.11.3.164 metric 400
Any help appreciated.
Best Regards.
