Opennebula says that the vm is still running if i stop it with the command halt (os: centos). So i cant configure a hook to restart the vm. Does anyone know how to deal with this situation?
Thank you in advance. (Sorry for my english
if I understand you correct you would like to install a VM_HOOK that is executed everytime you halt the VM from the inside.
Maybe you can use a VM_HOOK like the one presented in the following thread:
it most likely does not met all your needs but maybe it is a good starting point.
Hope this helps
Bernhard J. M. Grün
