Hello community,
at first I would like to wish everyone a happy new year.
I am looking for a solution for people who accidentally poweroff Virtual Machines which are production systems using commands like halt, poweroff or something like this. In shorts I would like to guarantee that some VMs work in a “always on” mode.
Is there a working solution which is easier to handle than my workaround (below)?
Preface: Previously we have used Ganeti which provides a feature to autorestart a VM in case the QEMU system crashes (or a user shuts down its Virtual Machine from the inside of the VM. Only a shutdown from the Ganeti command line leads to a permanent shutdown state.
I already found a workaround to enable such a mechanism in OpenNebula but my solution is not free of fuss unfortunately.
Either way I like to present my workaround in the following in the hope that I can help someone.
At first I created a VM_HOOK that catches every time a VM enters the POWEROFF state.
VM_HOOK = [
name = "hook_vm_on_poweroff",
on = "CUSTOM",
state = "POWEROFF",
lcm_state = "LCM_INIT",
command = "ft/hook_vm_on_poweroff.sh",
arguments = "$ID $PREV_STATE $PREV_LCM_STATE" ]
Then I created the following script ft/hook_vm_on_poweroff.sh as handler for the hook:
#!/bin/bash
if [ "$2" == "ACTIVE" ] && [ "$3" == "SHUTDOWN_POWEROFF" ]; then
IS_VM_ALWAYS_ON=$(onevm show $1 | grep VM_ALWAYS_ON | grep -q true && echo "true")
if [ "x$IS_VM_ALWAYS_ON" == "xtrue" ]; then
echo "Restarting VM $1 - VM_ALWAYS_ON is enabled"
onevm resume $1
fi
fi
This script checks whether the VM was running previously.
If so, it also checks if the VM has set the following variable:
VM_ALWAYS_ON=true (I added that variable using the command onevm update VM_ID)
If all conditions are met the command onevm resume VM_ID is issued to restart the VM.
A major downside of my workaround is that the hook also fires if someone shuts down the VM via the Sunstone or onevm poweroff VM_ID
Do you know a better and easier way to implement this?
Many thanks in advance!
Best regards,
Bernhard J. M. Grün
