I have just updated my OpenNebula from 14.10.1 to 14.12.1 and our ceph datastore is now showing as 100% used.
Looking through the logs I am seeing:
2015-07-21T11:09:40.660207+01:00 dev-hn1 oned[16896]: [Z0][ImM][I]: Command execution fail: /var/lib/one/remotes/datastore/ceph/monitor PERTX0RSSVZFUl9BQ1RJT05fREFUQT48REFUQV...
If I try to run that command as either root or oneadmin I get the following:
/usr/lib/ruby/1.8/rexml/parsers/treeparser.rb:92:in `parse': #<REXML::ParseException: #<NoMethodError: undefined method `[]' for nil:NilClass> (REXML::ParseException)
/usr/lib/ruby/1.8/rexml/parsers/baseparser.rb:330:in `pull'
/usr/lib/ruby/1.8/rexml/parsers/treeparser.rb:22:in `parse'
/usr/lib/ruby/1.8/rexml/document.rb:245:in `build'
/usr/lib/ruby/1.8/rexml/document.rb:43:in `initialize'
/var/lib/one/remotes/datastore/ceph/../xpath.rb:58:in `new'
Exception parsing
Line:
Position:
Last 80 unconsumed characters:
</LN_TARG>
/usr/lib/ruby/1.8/rexml/parsers/baseparser.rb:418:in `pull'
Exception parsing
Line:
Position:
</LN_TARG
Line:
Position:
</LN_TARG
        from /usr/lib/ruby/1.8/rexml/document.rb:245:in `build'
        from /usr/lib/ruby/1.8/rexml/document.rb:43:in `initialize'
        from /var/lib/one/remotes/datastore/ceph/../xpath.rb:58:in `new'
/var/lib/one/remotes/datastore/ceph/../libfs.sh: line 238: RANDOM % 0: division by 0 (error token is "0")
ERROR MESSAGE --8<------
Datastore template missing 'BRIDGE_LIST' attribute.
ERROR MESSAGE ------>8--
I have attempted the fix suggested in After updating from 4.10 to 4.12 ceph became 100% used however I am still seeing the same issue when running the command myself.
Thanks
Alex
