Opennebula with ceph
Hi ,
my name is Heinz, i´m from Austria and need some help for using ceph datastore with opennebula.
i readed a lot of articles in the forum the last week and tried out different things but i don´t get
a datastore running. i know there are some topics with the same questions but the anwsers ar not
helpfull for me.
My questions:
i think my libvirt user has sufficient rights. I can read out the datastore on ceph with:
rbd ls -p one --id libvirt
it works from frontend and nodes
but in the sunstone gui i cannot read out the size.
Which user needs rights on which node? Please please for help.
Regards Heinz
Hi @onenewbie,
Do you found solution for your questions? I am beginning with Opennebula + Ceph and have the same doubts.:corar:
if you have solved it , can share with us?
you should check your logs (/var/log/one/oned.logs), the error will be shown there
