Ceph snapshot VM "unsupported configuration : internal snapshot for disk vda unsupported for storage type raw"
I run 3 hosts with Ceph currently in a testing environment.
I’d like to take a snapshot of a VM, but when I do so it fails with the following error in the logs:
Fri Oct 20 19:44:52 2017 [Z0][VMM][D]: Message received: LOG I 76 Command execution fail: ‘if [ -x “/var/tmp/one/vmm/kvm/snapshot_create” ]; then /var/tmp/one/vmm/kvm/snapshot_create one-76 0 76 kvm-02; else exit 42; fi’
Fri Oct 20 19:44:52 2017 [Z0][VMM][D]: Message received: LOG I 76 error: unsupported configuration: internal snapshot for disk vda unsupported for storage type raw
Fri Oct 20 19:44:52 2017 [Z0][VMM][D]: Message received: LOG E 76 Could not create snapshot for domain one-76.
Fri Oct 20 19:44:52 2017 [Z0][VMM][D]: Message received: LOG I 76 ExitCode: 255
Fri Oct 20 19:44:52 2017 [Z0][VMM][D]: Message received: SNAPSHOTCREATE FAILURE 76 Could not create snapshot for domain one-76.
Fri Oct 20 19:44:53 2017 [Z0][InM][D]: Host kvm-03 (3) successfully monitored.
This is on a CentOS 7 VM built with the App from opennebula.
I confirmed and it’s Qcow2 as well…
Am I doing something wrong?
CentOS 7 latest, 5.4.1 across all HV’s.
Make snapshot of VM.
See above for error log.
If I remember right you can only do that with raw images, there are issues with Ceph and qcow2 images. Try the same using a raw image
AFAIK on KVM it works with qcow2 files. This line is returned by libvirt:
Best Regards,
So in combination with Ceph it doesn’t work?
AFAIK currently it doesn’t work with any storage that is using raw disks.
