Unable to create VM snapshot using Ceph
Hi everyone,
In my department, we are trying to bring up an Opennebula environment with a Ceph storage to handle our virtualization needs. We have already installed and configured the frontend and attached a couple of nodes.
Most of the features are working as expecting but we have struggled with the snapshots and we haven’t been able to make them work. We have been reading a lot about how to integrate Ceph with Opennebula but finally, we decide to ask
here for help.
So, here is the problem, when I try to create a snapshot of a persistent VM, the following error mesage came up:
Tue Mar 19 10:01:23 2019 [Z0][VM][I]: New LCM state is HOTPLUG_SNAPSHOT
Tue Mar 19 10:01:23 2019 [Z0][VMM][I]: Command execution failed (exit code: 255): 'if [ -x "/var/tmp/one/vmm/kvm/snapshot_create" ]; then /var/tmp/one/vmm/kvm/snapshot_create one-13 0 13 nebula-202; else exit 42; fi'
Tue Mar 19 10:01:23 2019 [Z0][VMM][I]: error: unsupported configuration: internal snapshot for disk vda unsupported for storage type raw
Tue Mar 19 10:01:23 2019 [Z0][VMM][E]: Could not create snapshot for domain one-13.
Tue Mar 19 10:01:23 2019 [Z0][VMM][E]: Error creating new VM Snapshot: Could not create snapshot for domain one-13.
Tue Mar 19 10:01:23 2019 [Z0][VM][I]: New LCM state is RUNNING
I’ve been looking for changing the disk format, changing the datastore configuration, changing the VM template but nothing works…
Here is the Image Datastore and the System Datastore configuration :
Ceph System Datastore
DATASTORE 102 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTERS       : 100
TYPE           : SYSTEM
DS_MAD         : -
TM_MAD         : ceph
BASE PATH      : /var/lib/one//datastores/102
DISK_TYPE      : RBD
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 22T
FREE:          : 22T
USED:          : 11G
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="mixed"
BRIDGE_LIST="..."
CEPH_HOST="..."
CEPH_SECRET="..."
CEPH_USER="oneadmin"
CLUSTER="100"
DISK_TYPE="RBD"
DS_MIGRATE="NO"
POOL_NAME="one"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
SHARED="YES"
TM_MAD="ceph"
TYPE="SYSTEM_DS"
IMAGES
Ceph Image Datastore
DATASTORE 103 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTERS       : 100
TYPE           : IMAGE
DS_MAD         : ceph
TM_MAD         : ceph
BASE PATH      : /var/lib/one//datastores/103
DISK_TYPE      : RBD
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 22T
FREE:          : 22T
USED:          : 11.1G
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
BRIDGE_LIST="..."
CEPH_HOST="..."
CEPH_SECRET="..."
CLONE_TARGET="SELF"
CLONE_TARGET_SHARED="SELF"
CLONE_TARGET_SSH="SYSTEM"
DISK_TYPE="RBD"
DISK_TYPE_SHARED="RBD"
DISK_TYPE_SSH="FILE"
DRIVER="raw"
DS_MAD="ceph"
LN_TARGET="NONE"
LN_TARGET_SHARED="NONE"
LN_TARGET_SSH="SYSTEM"
POOL_NAME="one"
RESTRICTED_DIRS="/"
TM_MAD="ceph"
TM_MAD_SYSTEM="ssh,shared"
TYPE="IMAGE_DS"
IMAGES
17
18
Hi @chromamaster ,
It`s not possible take VM snapshot using Ceph. Instead this, you can take snapshot of the VM disk.
Maybe some Opennebula developer can explaine-us why not possible this…
Ceph RBD prefers RAW format, and it seems that is how ONe feeds ceph.
To confirm this, I downloaded a marketplace image which has format qcow2. I exported the relevant RBD and inspected the file with qemu-img info. The format of this export is actually raw.
From the ceph manual QEMU and Block Devices — Ceph Documentation :
The raw data format is really the only sensible format option to use with RBD. Technically, you could use other QEMU-supported formats (such as qcow2 or vmdk ), but doing so would add additional overhead, and would also render the volume unsafe for virtual machine live migration when caching (see below) is enabled.
Conjecture :
qemu snapshots RAW disk as qcow2 files, and qemu appends QCOW2 disk with a snapshot. In ONe + Ceph, the VM disk is an RBD, so ceph is handling the snapshot process, which means there are no qcow2 snapshots of the VM. So active memory and state of the VM are not getting snapshotted since only the disk is getting snapshotted.
From end-user usability standpoint, would be great if VM snapshotting section would at least snapshot all the disks at the same time
