@ahuertas I have the same issue @way is seeing with the sunstone datastore view not updating used capacity of the pool. I recently just created a HA cluster with 3oned servers, 2 kvm hosts, and 3 sunstone with the same ceph pool I had been using for 5.6 testing, now with 5.8.1 testing. IIRC this was working correctly with version 5.8, but my environment is a little different now so maybe something is misconfigured on my end???
I have 10 VMs with ~300 MiB disk usage each (8GB provisioned disk), 1 OS image @ 1.2GiB, and an empty generic storage datablock @ 20GiB.
The capacity shown is typically the provisioned/total.
Here is ceph output
[oneadmin@front2 root]$ rbd du -p cachepool
NAME PROVISIONED USED
foo 4 GiB 0 B
one-4 8 GiB 1.2 GiB
one-5@snap 8 GiB 1.2 GiB
one-5 8 GiB 0 B
one-5-10-0 8 GiB 272 MiB
one-5-11-0 8 GiB 272 MiB
one-5-2-0 8 GiB 316 MiB
one-5-3-0 8 GiB 316 MiB
one-5-4-0 8 GiB 272 MiB
one-5-5-0 8 GiB 272 MiB
one-5-6-0 8 GiB 272 MiB
one-5-7-0 8 GiB 272 MiB
one-5-8-0 8 GiB 272 MiB
one-5-9-0 8 GiB 272 MiB
one-6 20 GiB 0 B
120 GiB 5.2 GiB
one-6 generic storage image oned log output:
Mon May 6 10:10:20 2019 [Z0][ImM][I]: Image created and ready to use
Mon May 6 10:10:20 2019 [Z0][InM][D]: Monitoring datastore Ceph-Images (103)
Mon May 6 10:10:22 2019 [Z0][ImM][D]: Datastore Ceph-Images (103) successfully monitored.
output of oneimage show 5:
[oneadmin@front2 root]$ oneimage show 5
IMAGE 5 INFORMATION
NAME : CentOS 7 - KVM
USER : oneadmin
GROUP : oneadmin
LOCK : None
DATASTORE : Ceph-Images
TYPE : OS
REGISTER TIME : 05/05 16:58:54
PERSISTENT : No
SOURCE : hddpool/one-5
PATH : https://marketplace.opennebula.systems//appliance/4e3b2788-d174-4151-b026-94bb0b987cbb/download/0
STATE : used
RUNNING_VMS : 10
OWNER : um-
GROUP : —
OTHER : —
IMAGE TEMPLATE
DEV_PREFIX=“vd”
FORMAT=“qcow2”
FROM_APP=“28”
FROM_APP_MD5=“dbc81ae029a17e12e51c0aac3cc5ac4d”
FROM_APP_NAME=“CentOS 7 - KVM”
VIRTUAL MACHINES
11 oneadmin oneadmin two7 runn 1.0 570.7M cloud3.ecs 0d 00h14
10 oneadmin oneadmin two6 runn 0.0 568.8M cloud4.ecs 0d 00h14
9 oneadmin oneadmin two5 runn 0.0 549.6M cloud3.ecs 0d 00h14
8 oneadmin oneadmin two4 runn 0.0 586.4M cloud4.ecs 0d 00h14
7 oneadmin oneadmin two0 runn 0.0 565.2M cloud3.ecs 0d 00h14
6 oneadmin oneadmin two1 runn 0.0 572.6M cloud4.ecs 0d 00h14
5 oneadmin oneadmin two2 runn 0.0 542.7M cloud3.ecs 0d 00h14
4 oneadmin oneadmin two3 runn 0.0 590.6M cloud4.ecs 0d 00h14
3 oneadmin oneadmin 0 runn 0.0 501.8M cloud3.ecs 0d 17h19
2 oneadmin oneadmin 1 runn 0.0 665.7M cloud4.ecs 0d 17h19
onevm show 11:
[oneadmin@front2 root]$ onevm show 11
VIRTUAL MACHINE 11 INFORMATION
USER : oneadmin
GROUP : oneadmin
STATE : ACTIVE
LCM_STATE : RUNNING
LOCK : None
RESCHED : No
HOST : cloud3.ecstest.com
CLUSTER ID : 0
CLUSTER : default
START TIME : 05/06 10:07:51
END TIME : -
DEPLOY ID : one-11
VIRTUAL MACHINE MONITORING
CPU : 0.0
MEMORY : 570.9M
NETTX : 0K
NETRX : 0K
DISKRDBYTES : 139291972
DISKRDIOPS : 6570
DISKWRBYTES : 15672320
DISKWRIOPS : 320
OWNER : um-
GROUP : —
OTHER : —
VM DISKS
ID DATASTORE TARGET IMAGE SIZE TYPE SAVE
0 Ceph-Image vda CentOS 7 - KVM -/8G rbd NO
1 - hda CONTEXT -/- - -
VIRTUAL MACHINE HISTORY
SEQ UID REQ HOST ACTION DS START TIME PROLOG
0 - - cloud3.ecste none 104 05/06 10:09:40 0d 00h13m 0h00m04s
USER TEMPLATE
LOGO=“images/logos/centos.png”
SCHED_MESSAGE=“Mon May 6 10:09:08 2019 : Cannot dispatch VM to any Host. Possible reasons: Not enough capacity in Host or System DS, dispatch limit reached, or limit of free leases reached.”
VIRTUAL MACHINE TEMPLATE
AUTOMATIC_DS_REQUIREMENTS="(“CLUSTERS/ID” @> 0)"
AUTOMATIC_NIC_REQUIREMENTS="(“CLUSTERS/ID” @> 0)"
AUTOMATIC_REQUIREMENTS="(CLUSTER_ID = 0) & !(PUBLIC_CLOUD = YES)"
CONTEXT=[
DISK_ID=“1”,
NETWORK=“YES”,
SSH_PUBLIC_KEY="",
TARGET=“hda” ]
CPU=“1”
GRAPHICS=[
LISTEN=“0.0.0.0”,
PORT=“5911”,
TYPE=“vnc” ]
MEMORY=“768”
OS=[
ARCH=“x86_64” ]
TEMPLATE_ID=“1”
TM_MAD_SYSTEM=“ceph”
VMID=“11”
Size is -/8 for the rbd disk. Idk what is up with the scheduling message, i batch created these VMs and onehost show says it is running on my host. I can’t vnc to confirm this vm is ACTUALLY running because I haven’t quite set it up on my external sunstone servers yet.
