Opennebula not create VM in Ceph pool
Hi everyone,
I’m (trying)using Opennebula with Ceph with RBD. I was configurated Opennebula according with manual, and the Ceph pool is listed in Datastore section. But when I create the VM they is created in host filesystem, not in RBD pool, and not happen nothing error. Do I making any wrong? Can anyone help-me?
Edit: I saw that “onevm” returns VM in Ceph pool, but if I check RBD pool the image not exists, and in host filesystem image is present.
See:
$ onevm show 106
VIRTUAL MACHINE HISTORY
SEQ UID REQ HOST ACTION DS START TIME PROLOG
0 - - host1 none 102 12/12 14:56:07 0d 16h55m 0h00m55s
SCHED_DS_REQUIREMENTS="ID=“102"”
TEMPLATE_ID=“29”
$ onetemplate show 29
$ onedatastore show 102
DATASTORE 102 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : SYSTEM
DS_MAD : -
TM_MAD : ceph
BASE PATH : /var/lib/one//datastores/102
DISK_TYPE : RBD
STATE : READY
I found the problem: I was using images from datastore of filesystem. I created image datastore in same Ceph pool that Opennebula system datastore, and VM was created in Ceph correctly pool.
Abstract: If I understand, for use a Ceph pool for system datastore, do you need create an associated image datastore em the same Ceph pool. It is correct?
Yes, you need to point both image and system datastores to the same pool. IIRC it mentioned in the manual.
