Chown method for Hosts
I notice there isn’t a Chown method for hosts but there are columns in the database for it. I probably need it for something I am working on. Is there any reason it won’t work if I add it ?
Hi, host belongs to cluster and you can set ACL rules to user/group to use cluster
I specifically need it for Hosts I was just wondering why it wasn’t implemented…
Hello @feldsam ,
Can a user change owner of VM
onevm chown vmid userid --user oneadmin works fine.
But onevm chown vmid userid --user user doesn’t work.
Could you please suggest?
Thanks!!
Hi, I don’t understand why you are try to supply userid along with username
