I need a nudge in the right direction to properly configure my VDC’s
I basically want my default group of users to get a general use pool of hosts. And a special group of users to get access to a special pool of hosts. I want to only have one cluster as they share networks, images, datastores etc.
The only cluster I have is cluster 0. Nothing is explicitly added to it. but it inherits everything right?
I want 2 VDC’s the default / general VDC which can, or can’t be VDC 0 depending on what i need to do to make this work. And my special VDC (vdc 101)
I’ve tried making my general use VDC both be 0 and 102 but neither seem to to work.
What I find is happening is if my general VDC does not contain cluster 0 but contains and explicit list of general use hosts. The scheduler is not able to find a suitable host for deployment. And if I add the cluster then the schedule does not pay attention to the hosts in the VDC and ends up deploying instances onto my special hosts I guess because they are in the cluster.
Let me know if you need more info. Thanks
