As the title says I created a VDC with only a cluster ressource (not vnets,hosts,datastores -> these are all part of the cluster). A usergroup assigned to this VDC can use all host, vnet and ds-ressources EXCEPT the vnets which are reservations. I believe this is wrong, because the inheritation logic is broken at this point.
I doublechecked that the reservation vnet is part of the above cluster.
Thanks for your support
Uli
5.4.6
see above
groups assigned to vdc cannot use a vnet based on a reservation
groups assigned to vdc should be able to use a vnet based on a reservation
