Under which deployment option do we specify the datastore to be used to store the virtual machines?
Hello @javieralaez
Can you clarify what you mean with “deployment option”? Are you looking on the UI of OpenNebula?
For Datastores management, I would suggest you to start from the documentation:
Datastores.
At the bottom you’ll find the section for Sunstone.
Regards,
