I have openstack image of gentoo. does anyone have any experience in converting it to work with opennebula?
No Problem. Install https://github.com/jirutka/one-context to the image. Should work.
ip address does not get set, expanded the disk perfectly tho think maybe I am missing something: if I run it manually
- Starting vmcontext …
cat: /sys/class/net/bonding_masters/address: Not a directory - Script /etc/one-context.d/00-network failed
What does cat /mnt/cdrom/context.sh say?
actually I dont seem to have anything mounted on /mnt
Well i think thats part of the problem. You can take a look at /etc/init.d/vmcontext to see what should going on.
