Not able to import the datastore and template error message is showing Cannot contact server: is it running and reachable? Opennebula version 5.4.6
hi Abhaya_c,
i understand that you are running Sunstone and you cannot perform any action.
this message Cannot contact server: is it running and reachable? tell us that Oned daemon (OpenNebula core and main process) is not running.
Make sure that your OpenNebula installation is working properly:
http://docs.opennebula.org/5.6/intro_release_notes/concepts_terminology/intro.html#
Regards.
Dear Semedi
Below services are running
systemctl list-units | grep open
usr-openv.mount loaded active mounted /usr/openv
opennebula-flow.service loaded active running OpenNebula Flow Service
opennebula-novnc.service loaded active running OpenNebula noVNC Server
opennebula-scheduler.service loaded active running OpenNebula Cloud Scheduler Daemon
opennebula-sunstone.service loaded active running OpenNebula Web UI Server
opennebula.service loaded active running OpenNebula Cloud Controller Daemon
Regards
