Difficulty understanding how to use Remote datastore
I am new to Open Nebula and I’m having some trouble understanding datastores and would appreciate any advice.
We have setup the front-end and a KVM node and have a quite large 30TB FreeNAS machine we’d like to use to store our cloud data on. I can mount the NFS from both the front-end and KVM node without issue however I do not know how to create a datastore using this NFS as I do not see anywhere to specify a remote host. I’ve read through so much documentation and I cannot seem to find anything in regards to a remote datastore.
Has anyone successfully mounted a remote NFS as a datastore before? What am I missing here?
Does anyone have any advice on this?
Regards,
Zac
Hi Zac,
In brief you sould mount the NFS filesystem on all nodes manually or via fstab and create symlink from /var/lib/one/datastores/ to the NFS mount point.
More details here:
http://docs.opennebula.org/5.2/deployment/open_cloud_storage_setup/fs_ds.html
Your use case sound like filesystem datastore in ‘shared’ mode.
Kind Regards,
Kind Regards,
Hi
You must to use a Shared Datastore.
http://docs.opennebula.org/5.2/deployment/open_cloud_storage_setup/fs_ds.html#fs-ds
At /var/lib/one/datastores you must to link to your nfs mounted dir.
Example:
I mount my NFS export at /mnt/opennebulaA and create the images and system on it.
Then link to the /mnt/OpenNebula/system and /mnt/OpenNebula/images to the /var/lib/one/datastores/0 and /var/lib/one/datastores/1
I hope helps to you…
Thank you very much guys, that makes perfect sense!
