We don’t use/configure IPV6 so we have it disabled in our servers.
I am trying to setup VLAN based Virtual Networks. I obviously only assign IPV4 addresses.
However when I try to start VMs I get IPV6 error messages:
Mon Nov 13 06:44:16 2017 [Z0][VMM][I]: ip6tables v1.4.21: can't initialize ip6tables table `filter': Address family not supported by protocol
Mon Nov 13 06:44:16 2017 [Z0][VMM][I]: Perhaps ip6tables or your kernel needs to be upgraded.
Mon Nov 13 06:44:16 2017 [Z0][VMM][E]: post: Command Error: sudo ip6tables -S
Mon Nov 13 06:44:16 2017 [Z0][VMM][E]: post: ["/var/tmp/one/vnm/command.rb:62:in `block in run!'",
My guess is that it is trying to apply default IPV6 rules for when no IPV6 is configured.
However, what can I do if IPV6 is disabled completely?
Looks like you have to install ip6tables on compute nodes or update vnm driver to not run ip6tables command.
There is no check about network have/not have ipv6 configured in security groups.
You can open issue on dev.opennebula.org or update that file on frontend node and them onehost sync --force to update that file (by removing ip6tables cmds) on compute nodes also
Hello, I understand. So you have to temporary update that driver by deleting ip6 sections and open issue on github, because redmine was discontinued few days ago
