Error Importing existing VMs
I´m running the OpenNebula 5.4.15 on a VMware enviroment, everything looks fine but when I try to import the existing VMs on the Wilds tab I receive the messages bellow:
Some show:
[one.vm.allocate] DISK 0: Cannot acquire image 0, it is persistent and already in use
In some others the message is:
Error creating disk from template: [one.image.allocate] Not enough space in datastore
Does anyone know what to do?
Thanks
Check if any image used by the Wild VM is already imported
This is a bug, which has been solved in 5.6. Disable temporarily DATASTORE_CAPACITY_CHECK in /etc/one/oned.conf (you need to restart oned).
Import wild VMs in vCenter shouldn't check datastore capacity · Issue #1880 · OpenNebula/one · GitHub
Still cant move my enviroment to the software. I´ve upgraded to vOneCloud 3.2 but the result is the same.
On the new enviroment I could move only one of then. Those VMs where created on vCenter based on the the same template. Is there anything to do or do I need to create the VMs again (not a possible solution)
