Hi Here.
I’m new to the forum.
I’m trying to install Opennebula on Ubuntu 14.04 (using VmWare Workstation. This is for an internship report).
When I try to install Ruby Runtime Environment, I encounter the following error:
Rake = “/ usr / bin / rake” gem install --no-ri --no-rdoc aws-sdk --version "= 1.66"
Building native extensions. This could take a while …
ERROR: Error installing aws-sdk:
ERROR: Failed to build gem native extension.
Current directory: /var/lib/gems/2.4.0/gems/nokogiri-1.8.0/ext/nokogiri
/usr/bin/ruby2.4 -r ./siteconf20170703-14885-1me2n3a.rb extconf.rb
Mkmf.rb can not find header files for ruby at /usr/lib/ruby/include/ruby.h
Extconf failed, exit code 1
Gem files will remain installed in /var/lib/gems/2.4.0/gems/nokogiri-1.8.0 for inspection.
Results logged to /var/lib/gems/2.4.0/extensions/x86_64-linux/2.4.0/nokogiri-1.8.0/gem_make.out
Error executing rake = “/ usr / bin / rake” gem install --no-ri --no-rdoc aws-sdk --version “= 1.66”
Can someone unlock me please ??? Thanks in advance
