Example on how to use XML RPC with Java
Hi all!!
I am trying to use XML RPC in a Java program…
for example…
if I wanted to know the hosts like the command onehost list does…
what should I do?
I look in the guide
look the onehost tab
and find the row
list top | one.hostpool.info | HOST:USE
then what should I do?
I’ve found the solution!!
I hope this help some newbye like me :smile:
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package onetest;
import java.net.MalformedURLException;
import java.net.URL;
import org.apache.xmlrpc.XmlRpcException;
import org.apache.xmlrpc.client.XmlRpcClient;
import org.apache.xmlrpc.client.XmlRpcClientConfigImpl;
 * @author paolo
public class OpenNebulaClient{
    private XmlRpcClient client = new XmlRpcClient();
    private XmlRpcClientConfigImpl config = new XmlRpcClientConfigImpl();
    private String session ="oneadmin:password";
    public OpenNebulaClient(String server_url){
       try{
           this.config.setServerURL(new URL(server_url));
           this.client.setConfig(this.config);
       catch(MalformedURLException e){
           System.err.println(e);
    public void getUserInfo(int id) throws XmlRpcException{
        Object[] params = {session,id};
        try {
            Object[] result = (Object[])this.client.execute("one.user.info",params);
                if(!result[0].equals(null)) {
                    boolean success = (Boolean)result[0];
                    String str_res = (String)result[1];
                    System.out.println("success="+success);
                    System.out.println("result="+str_res);
                else{
                    System.out.println("success=0");
        catch (XmlRpcException e) {
            //e.printStackTrace();
    public static void main(String[] args){
        OpenNebulaClient on_client = new OpenNebulaClient("http://localhost:2633/RPC2");
        try{
            on_client.getUserInfo(0);
        catch(XmlRpcException xmlrpce){
            System.err.println(xmlrpce);
You may be also interested in the java bindings we provide:
http://docs.opennebula.org/4.14/integration/system_interfaces/java.html
Thank you Carlos!
can I ask if there’s a way to use xml-rpc methods with curl command?
what is the xml equivalent of a command like “one.host.info”?
thank you
I know for a fact that you can use curl to access an xmlrpc api, but I don’t have any examples for the OpenNebula api.
Regards
