This is my VR:
ID 98
Name vr-vr-192-route
State ACTIVE
LCM State RUNNING
Host [S#hosts-tab/2)
IP 0: 172.16.238.* management interface
1: 192.168.10.3 subnet-1
2: 192.168.10.131 subnet-2
Deploy ID 506165ea-40ac-4887-8b09-49fb2f375d2f
Reschedule no
Virtual Router 14
Attributes
INPUTS_ORDER ONEAPP_VNF_DHCP4_ENABLED,ONEAPP_VNF_DHCP4_INTERFACES,ONEAPP_VNF_DHCP4_LEASE_TIME,ONEAPP_VNF_DNS_ENABLED,ONEAPP_VNF_DNS_INTERFACES,ONEAPP_VNF_DNS_MAX_CACHE_TTL,ONEAPP_VNF_DNS_USE_ROOTSERVERS,ONEAPP_VNF_HAPROXY_ENABLED,ONEAPP_VNF_HAPROXY_INTERFACES,ONEAPP_VNF_LB_ENABLED,ONEAPP_VNF_LB_INTERFACES,ONEAPP_VNF_NAT4_ENABLED,ONEAPP_VNF_NAT4_INTERFACES_OUT,ONEAPP_VNF_SDNAT4_ENABLED,ONEAPP_VNF_SDNAT4_INTERFACES
LXD_SECURITY_PRIVILEGED true
MEMORY_UNIT_COST MB
ONEAPP_VNF_DHCP4_ENABLED YES
ONEAPP_VNF_DHCP4_INTERFACES !eth0
ONEAPP_VNF_DHCP4_LEASE_TIME 3600
ONEAPP_VNF_DNS_ENABLED YES
ONEAPP_VNF_DNS_INTERFACES !eth0
ONEAPP_VNF_DNS_MAX_CACHE_TTL 3600
ONEAPP_VNF_DNS_USE_ROOTSERVERS YES
ONEAPP_VNF_HAPROXY_ENABLED YES
ONEAPP_VNF_LB_ENABLED YES
ONEAPP_VNF_NAT4_ENABLED YES
ONEAPP_VNF_NAT4_INTERFACES_OUT eth0
ONEAPP_VNF_SDNAT4_ENABLED YES
VROUTER YES
From Virtual router I can connect both Vnet Vms but inside any subnet Vm i cant able to ping another subnet vm.
also i could not see this file vrouter:~# cat /etc/one-appliance/config
cat: /etc/one-appliance/config: No such file or directory
vrouter:~#
Checked onegate service is running fine in nebula but router vm cant able to reach hit.
Can you sugest best solution?
