Failed to create kvm virtual machine
This is the log content of the virtual machine:
Wed Feb 15 11:31:29 2023 [Z0][VM][I]: New state is ACTIVE
Wed Feb 15 11:31:29 2023 [Z0][VM][I]: New LCM state is PROLOG
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: Command execution failed (exit code: 255): /var/lib/one/remotes/tm/ssh/clone root:/var/lib/one//datastores/1/74cc384b89badd6f34dcb921acd95847 43.2x.2x.102:/var/lib/one//datastores/0/10/disk.0 10 1
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: clone: Cloning /var/lib/one/datastores/1/74cc384b89badd6f34dcb921acd95847 in /var/lib/one/datastores/0/10/disk.0
Wed Feb 15 11:31:32 2023 [Z0][TrM][E]: clone: Command " set -e -o pipefail
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: if [ -d "/var/lib/one/datastores/1/74cc384b89badd6f34dcb921acd95847.snap" ]; then
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: SRC_SNAP="74cc384b89badd6f34dcb921acd95847.snap"
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: fi
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: tar -C /var/lib/one/datastores/1 --transform="flags=r;s|74cc384b89badd6f34dcb921acd95847|disk.0|" -cSf - 74cc384b89badd6f34dcb921acd95847 $SRC_SNAP | ssh 43.2x.2x.102 "tar -xSf - -C /var/lib/one/datastores/0/10"" failed: Permission denied, please try again.
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: Permission denied, please try again.
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: oneadmin@root: Permission denied (publickey,password).
Wed Feb 15 11:31:32 2023 [Z0][TrM][I]: Error copying /var/lib/one/datastores/1/74cc384b89badd6f34dcb921acd95847 to 43.2x.2x.102:/var/lib/one//datastores/0/10/disk.0
Wed Feb 15 11:31:32 2023 [Z0][TrM][E]: Error executing image transfer script: INFO: clone: Cloning /var/lib/one/datastores/1/74cc384b89badd6f34dcb921acd95847 in /var/lib/one/datastores/0/10/disk.0 ERROR: clone: Command " set -e -o pipefail if [ -d "/var/lib/one/datastores/1/74cc384b89badd6f34dcb921acd95847.snap" ]; then SRC_SNAP="74cc384b89badd6f34dcb921acd95847.snap" fi tar -C /var/lib/one/datastores/1 --transform="flags=r;s|74cc384b89badd6f34dcb921acd95847|disk.0|" -cSf - 74cc384b89badd6f34dcb921acd95847 $SRC_SNAP | ssh 43.2x.2x.102 "tar -xSf - -C /var/lib/one/datastores/0/10"" failed: Permission denied, please try again. Permission denied, please try again. oneadmin@root: Permission denied (publickey,password). Error copying /var/lib/one/datastores/1/74cc384b89badd6f34dcb921acd95847 to 43.2x.2x.102:/var/lib/one//datastores/0/10/disk.0
Wed Feb 15 11:31:32 2023 [Z0][VM][I]: New LCM state is PROLOG_FAILURE
Looks like you haven’t done the SSH setup
I have achieved from the control end to the node end, and I can use the public key to log in. The fact that the host can be added successfully should prove that I have no problem configuring ssh. Or can you tell me how your ssh is configured?
