I want to run a virtual machine but I have this problem
Can you help me?In this cases I usually try to run the commands manually, sometimes it gives me more information about errors.
First and foremost, please check the rights on your datastore’s path.
Now I tried to run the virtual machine but I have another errors
I don’t know exactly if the problem is situated in the front end or in the node?Can you give me more informations about that because about the storage I worked with the internal storage without any transformations? Thank you for advancedDo you use Node as VM inside VM (nested VM) ?
In this case I recommend you change cpu-model to host-pasthrough for Node VM. And check it by running virt-host-validate .
