Hello, i went through deployment of firecracker node as per documentation for 6.0. Its a simple 1 node deployment. Ssh connection back and forth works without issues, firewall disabled and all packages deployed as per docs. However, my host is in err status and doesn’t connect. Can i enable some driver specific logging to see what is happening? What are the troubleshooting steps for the host connectivity/setup that you would recommend i check?
Are there any relevant messages in oned.log or monitord.log. Also you can start monitord with increased verbosity in monitord.conf [1,2]
[1] Monitoring Configuration — OpenNebula 6.0.3 documentation
[2] Monitoring Configuration — OpenNebula 6.0.3 documentation
