I’m able to successfully start a firecracker VM, but after about 30 seconds or so, it powers off. I’ve seen this issue mentioned in the forums here, but no solution that worked for me. I’m able to run a firecracker VM directly myself on the same host manually without issue. I’m using the OS images (Ubuntu, Alpine, Debian–all have the same issue) along with the Kernel Image (Kernel 5.4 x86_64 - Firecracker) from the Apps page. I’ve tried deploying both with and without the network. I’ve ran the network steps for firecracker setup so I don’t think that’s the issue.
Frontend:
opennebula-common-onecfg/stable,stable,now 6.8.0-1 all [installed,automatic]
opennebula-common/stable,stable,now 6.8.0-1 all [installed,automatic]
opennebula-context/jammy,jammy 4.14.0-1 all
opennebula-dbgsym/stable 6.8.0-1 amd64
opennebula-fireedge/stable,now 6.8.0-1 amd64 [installed]
opennebula-flow/stable,stable,now 6.8.0-1 all [installed]
opennebula-gate/stable,stable,now 6.8.0-1 all [installed]
opennebula-guacd/stable,now 6.8.0-1 amd64 [installed,automatic]
opennebula-libs/stable,stable,now 6.8.0-1 all [installed,automatic]
opennebula-node-firecracker/stable,now 6.8.0-1 amd64 [installed]
opennebula-node-kvm/stable,stable,now 6.8.0-1 all [residual-config]
opennebula-node-lxc/stable 6.8.0-1 amd64
opennebula-node-lxd/stable 6.8.0-1 amd64
opennebula-provision-data/stable,stable,now 6.8.0-1 all [installed,automatic]
opennebula-provision/stable,stable,now 6.8.0-1 all [installed]
opennebula-rubygems/stable,now 6.8.0-1 amd64 [installed,automatic]
opennebula-sunstone/stable,stable,now 6.8.0-1 all [installed]
opennebula-tools/stable,stable,now 6.8.0-1 all [installed,automatic]
opennebula/stable,now 6.8.0-1 amd64 [installed]
Host:
Firecracker v0.24.2
opennebula-common-onecfg/stable,now 6.8.0-1 all [installed,automatic]
opennebula-common/stable,now 6.8.0-1 all [installed,automatic]
opennebula-context/jammy 4.14.0-1 all
opennebula-fireedge/stable 6.8.0-1 amd64
opennebula-flow/stable 6.8.0-1 all
opennebula-gate/stable 6.8.0-1 all
opennebula-guacd/stable 6.8.0-1 amd64
opennebula-libs/stable 6.8.0-1 all
opennebula-node-kvm/stable,now 6.8.0-1 all [residual-config]
opennebula-provision-data/stable 6.8.0-1 all
opennebula-provision/stable 6.8.0-1 all
opennebula-rubygems/stable 6.8.0-1 amd64
opennebula-sunstone/stable 6.8.0-1 all
opennebula-tools/stable 6.8.0-1 all
opennebula/stable 6.8.0-1 amd64
Download the kernel and OS images and use the template below to start a firecracker VM.
I’m testing this on a virtualbox host (ubuntu 22.04) with nested virtualization enabled.
Template:
CONTEXT = [
NETWORK = "YES",
SSH_PUBLIC_KEY = "$USER[SSH_PUBLIC_KEY]" ]
CPU = "1"
DISK = [
IMAGE = "Debian 12",
IMAGE_UNAME = "oneadmin" ]
GRAPHICS = [
LISTEN = "0.0.0.0",
TYPE = "VNC" ]
HOT_RESIZE = [
CPU_HOT_ADD_ENABLED = "NO",
MEMORY_HOT_ADD_ENABLED = "NO" ]
MEMORY = "512"
MEMORY_RESIZE_MODE = "BALLOONING"
MEMORY_UNIT_COST = "MB"
NIC = [
NETWORK = "onprem-cluster-public",
NETWORK_UNAME = "oneadmin",
SECURITY_GROUPS = "0" ]
OS = [
KERNEL_CMD = "console=ttyS0 reboot=k panic=1 pci=off i8042.noaux i8042.nomux i8042.nopnp i8042.dumbkbd",
KERNEL_DS = "$FILE[IMAGE_ID=6]" ]
VCPU = "2"
VM starts successfully but then goes into shutdown. Log:
Tue Mar 19 13:44:18 2024 [Z0][VM][I]: New state is ACTIVE
Tue Mar 19 13:44:18 2024 [Z0][VM][I]: New LCM state is PROLOG
Tue Mar 19 13:44:28 2024 [Z0][VM][I]: New LCM state is BOOT
Tue Mar 19 13:44:28 2024 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/82/deployment.0
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: pre: Running /var/tmp/one/vnm/bridge/pre.d/firecracker
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: ExitCode: 0
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/mkdir -p.
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/113/82/vm.xml.
Tue Mar 19 13:44:29 2024 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/113/82/ds.xml.
Tue Mar 19 13:44:30 2024 [Z0][VMM][I]: Running command sudo -n /usr/sbin/one-clean-firecracker-domain -c /sys/fs/cgroup -v one-82 -t 60
Tue Mar 19 13:44:30 2024 [Z0][VMM][I]: Running command sudo -n /usr/sbin/one-prepare-firecracker-domain -c /sys/fs/cgroup -p 1024 -s /var/lib/one/datastores/113 -v 82
Tue Mar 19 13:44:30 2024 [Z0][VMM][I]: Running command /var/tmp/one/vmm/firecracker/map_context /var/lib/one/datastores/113/82/disk.1 /var/lib/one/datastores/113/82/disk.1
Tue Mar 19 13:44:30 2024 [Z0][VMM][D]: deploy: Creating VM: 'screen -dmS one-82 sudo -n jailer --id one-82 --node 0 --exec-file /usr/bin/firecracker --uid 9869 --gid 9869 -- --config-file deployment.file'
Tue Mar 19 13:44:30 2024 [Z0][VMM][I]: ExitCode: 0
Tue Mar 19 13:44:30 2024 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Tue Mar 19 13:44:30 2024 [Z0][VMM][I]: Successfully execute network driver operation: post.
Tue Mar 19 13:44:30 2024 [Z0][VM][I]: New LCM state is RUNNING
Tue Mar 19 13:46:38 2024 [Z0][LCM][I]: VM running but monitor state is POWEROFF
Tue Mar 19 13:46:38 2024 [Z0][VM][I]: New LCM state is SHUTDOWN_POWEROFF
Tue Mar 19 13:46:38 2024 [Z0][VM][I]: New state is POWEROFF
Tue Mar 19 13:46:38 2024 [Z0][VM][I]: New LCM state is LCM_INIT
VM should start and stay running.
