Fs_lvm with raw driver doesnt work with shared tm - 5.8
Hi
I recently upgraded a 5.6 installation to 5.8.1 and am not able to deploy VMs. We have an image datastore with fs_lvm and we use raw drivers. We have a System Datastore with shared driver
When we deploy a VM, we get an error as follows “[one.vm.deploy] Image Datastore does not support transfer mode: shared”
I have seen similar problems reported on qcow2/ssh for which there was a fix mentioned on the issue Image Datastore does not support transfer mode: ssh - #4 by angriukas
I tried copying the latest TM_MAD_CONF from one/share/etc/oned.conf at master · OpenNebula/one · GitHub but still the same error.
I see that in 5.8, TM_MAD includes a list of compatible system datastores as per Ruben.
I tried using COMPATIBLE_SYS_DS as per documentation but that doesn’t help either with the error
Am I missing something here ? Does it require a custom TM_MAD_CONF for it to work with fs_lvm ?
Hi
The solution seems to be to add TM_MAD_SYSTEM to the virtual machine templates as per Filesystem Datastore — OpenNebula 5.8.5 documentation
To select the (alternate) deployment mode, add the following attribute to the Virtual Machine template:
  • TM_MAD_SYSTEM="ssh"
We modified our template to shared and the VMs are getting deployed now
Wondering if there is a way to make this behavior as default as we have hundreds of templates and manually updating them could be cumbersome
we also modified the system datastore to be fs_lvm type and it worked without impact after the upgrade to 5.12
appreciate the update, thanks!
