I need to use net-ldap, but a recent version requires ruby 2.0, i used
gem install rails 4.2.4 and had some success for a while
gem -v
2.4.8
gem list
addressable (2.5.1, 2.4.0)
amazon-ec2 (0.9.17)
aws-sdk (2.9.43, 2.5.10)
aws-sdk-core (2.9.43, 2.5.10)
aws-sdk-resources (2.9.43, 2.5.10)
aws-sigv4 (1.0.0)
azure (0.7.9, 0.7.6)
azure-core (0.1.8, 0.1.4)
bigdecimal (1.3.2, 1.2.6)
builder (3.2.3, 3.2.2)
bundler (1.15.1)
bundler-unload (1.0.2)
configparser (0.1.6, 0.1.4)
curb (0.9.3)
daemons (1.2.4)
defaults (1.0.1)
eventmachine (1.2.3, 1.2.0.1)
executable-hooks (1.3.2)
faraday (0.12.1, 0.9.2)
faraday_middleware (0.11.0.1, 0.10.0)
gem-wrappers (1.2.7)
hashie (3.5.5, 3.4.4)
inflection (1.0.0)
io-console (0.4.6, 0.4.3)
jmespath (1.3.1)
json (2.1.0, 1.8.3, 1.8.1)
memcache-client (1.8.5)
mime-types (3.1, 2.99.2)
mime-types-data (3.2016.0521)
mini_portile2 (2.2.0, 2.1.0)
minitest (5.10.2, 5.4.3)
multipart-post (2.0.0)
mustermann (1.0.0)
mysql (2.9.1)
net-ldap (0.16.0, 0.12.1)
nokogiri (1.8.0, 1.6.8)
ox (2.5.0, 2.4.4)
parse-cron (0.1.4)
pkg-config (1.2.3, 1.1.7)
polyglot (0.3.5)
power_assert (1.0.2, 0.2.2)
psych (2.2.4, 2.0.8)
public_suffix (2.0.5)
rack (2.0.3, 1.6.4)
rack-protection (2.0.0, 1.5.3)
rake (12.0.0, 10.4.2)
rdoc (5.1.0, 4.2.0)
rubygems-bundler (1.4.4)
rubygems-update (2.6.12)
rvm (1.11.3.9)
scrub_rb (1.0.1)
sequel (4.47.0, 4.38.0)
sinatra (2.0.0, 1.4.7)
sqlite3 (1.3.13, 1.3.11)
systemu (2.6.5)
test-unit (3.2.4, 3.0.8)
thin (1.7.1, 1.7.0)
thor (0.19.4, 0.19.1)
tilt (2.0.7, 2.0.5)
to_yaml (0.3.0)
treetop (1.6.8)
trollop (2.1.2)
uuidtools (2.1.5)
xml-simple (1.1.5)
zendesk_api (1.14.4, 1.13.4)
running
ruby -Swd /var/lib/one/remotes/auth/ldap/authenticate user - pass
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems.rb:1222 - cannot load such file -- rubygems/defaults/operating_system
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems.rb:1231 - cannot load such file -- rubygems/defaults/ruby
/var/lib/one/remotes/auth/ldap/authenticate:42: warning: assigned but unused variable - pass
Exception `NameError' at /usr/local/rvm/gems/ruby-2.2.2/gems/psych-2.2.4/lib/psych/class_loader.rb:68 - uninitialized constant BigDecimal
Exception `NameError' at /usr/local/rvm/gems/ruby-2.2.2/gems/psych-2.2.4/lib/psych/class_loader.rb:68 - uninitialized constant Date
Exception `NameError' at /usr/local/rvm/gems/ruby-2.2.2/gems/psych-2.2.4/lib/psych/class_loader.rb:68 - uninitialized constant DateTime
Exception `NameError' at /usr/local/rvm/gems/ruby-2.2.2/gems/psych-2.2.4/lib/psych/core_ext.rb:17 - method `to_yaml' not defined in Object
Exception `NameError' at /usr/local/rvm/gems/ruby-2.2.2/gems/psych-2.2.4/lib/psych/core_ext.rb:30 - method `yaml_as' not defined in Module
Exception `NameError' at /usr/local/rvm/gems/ruby-2.2.2/gems/psych-2.2.4/lib/psych/deprecated.rb:82 - undefined method `to_yaml_properties' for class `Object'
/usr/lib/one/ruby/opennebula/xml_utils.rb:94: warning: `-' after local variable or literal is interpreted as binary operator
/usr/lib/one/ruby/opennebula/xml_utils.rb:94: warning: even though it seems like unary operator
/usr/lib/one/ruby/opennebula/xml_pool.rb:25: warning: method redefined; discarding old initialize
/usr/lib/one/ruby/opennebula/xml_element.rb:411: warning: previous definition of initialize was here
/usr/lib/one/ruby/opennebula/xml_pool.rb:31: warning: method redefined; discarding old each_element
/usr/lib/one/ruby/opennebula/xml_element.rb:417: warning: previous definition of each_element was here
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54 - cannot load such file -- nokogiri
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54 - cannot load such file -- nokogiri/2.2/nokogiri
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:133 - cannot load such file -- nokogiri/2.2/nokogiri
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54 - cannot load such file -- ox
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54 - cannot load such file -- xmlparser
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:133 - cannot load such file -- xmlparser
/usr/lib/one/ruby/opennebula/virtual_machine_pool.rb:297: warning: assigned but unused variable - acct_hash
/usr/lib/one/ruby/opennebula/host.rb:136: warning: ambiguous first argument; put parentheses or a space even after `-' operator
/usr/lib/one/ruby/opennebula/vdc.rb:176: warning: method redefined; discarding old add_host
/usr/lib/one/ruby/opennebula/vdc.rb:164: warning: previous definition of add_host was here
/usr/lib/one/ruby/opennebula/vdc.rb:192: warning: method redefined; discarding old del_host
/usr/lib/one/ruby/opennebula/vdc.rb:186: warning: previous definition of del_host was here
Exception `LoadError' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/site_ruby/2.2.0/rubygems/core_ext/kernel_require.rb:54 - cannot load such file -- net/ldap
/usr/local/rvm/gems/ruby-2.2.2/gems/net-ldap-0.16.0/lib/net/ldap/password.rb:22: warning: assigned but unused variable - attribute_value
/usr/local/rvm/gems/ruby-2.2.2/gems/net-ldap-0.16.0/lib/net/ldap/instrumentation.rb:15: warning: shadowing outer local variable - payload
/usr/local/rvm/gems/ruby-2.2.2/gems/net-ldap-0.16.0/lib/net/ldap/connection.rb:303: warning: assigned but unused variable - sort_control
Trying server server 1
/usr/lib/one/ruby/opennebula/ldap_auth.rb:79: warning: File.exists? is a deprecated name, use File.exist? instead
/usr/lib/one/ruby/opennebula/ldap_auth.rb:114: warning: File.exists? is a deprecated name, use File.exist? instead
Exception `IO::EINPROGRESSWaitWritable' at /usr/local/rvm/rubies/ruby-2.2.2/lib/ruby/2.2.0/socket.rb:54 - Operation now in progress - connect(2) would block
User username not found
Could not authenticate user username
The errors suggest mix-match of ruby versions that are expected and missing gems.
I am trying ldap/ldaps which I have gotten to work before. I had an issue with a self-signed cert and recent changes to ruby net-ldap. At this point, running
/usr/share/one/install_gems is not allowed as oneamdin, because of non-root. So i ran as root and now now all other gems are broken since install_gems uses ruby 1.9.1.
What is a sustainable way to use updated gems with OpenNeb 5.2?
