Connection to Azure seams to be working fine, but when trying to create a Linux VM (Ubuntu), I’ve been getting the following error on the VM log window:
Tue Feb 20 10:33:55 2018 [Z0][VM][I]: New state is ACTIVE
Tue Feb 20 10:33:55 2018 [Z0][VM][I]: New LCM state is PROLOG
Tue Feb 20 10:33:55 2018 [Z0][VM][I]: New LCM state is BOOT
Tue Feb 20 10:33:55 2018 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/114/deployment.0
Tue Feb 20 10:33:55 2018 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Tue Feb 20 10:34:06 2018 [Z0][VMM][I]: Command execution fail: /var/lib/one/remotes/vmm/az/deploy ‘/var/lib/one/vms/114/deployment.0’ ‘NebulaND01’ 116 NebulaND01
Tue Feb 20 10:34:06 2018 [Z0][VMM][I]: Error deploying Azure VM: e[31me[1mFailed to create virtual machine : e[31me[1mThe virtual machine image source is not valid.e[0me[0me[0me[0m
Tue Feb 20 10:34:06 2018 [Z0][VMM][I]: ExitCode: 255
Tue Feb 20 10:34:06 2018 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Tue Feb 20 10:34:06 2018 [Z0][VMM][E]: Error deploying virtual machine
Tue Feb 20 10:34:06 2018 [Z0][VM][I]: New LCM state is BOOT_FAILURE
This is the Azure host:
HOST 9 INFORMATION
CLUSTER : default
STATE : MONITORED
IM_MAD : az
VM_MAD : az
LAST MONITORING TIME : 02/20 13:12:59
HOST SHARES
RUNNING VMS : 1
MEMORY
TOTAL : 8.8G
TOTAL +/- RESERVED : 8.8G
USED (REAL) : 0K
USED (ALLOCATED) : 1024M
CPU
TOTAL : 500
TOTAL +/- RESERVED : 500
USED (REAL) : 0
USED (ALLOCATED) : 50
MONITORING INFORMATION
HOSTNAME="NebulaND01"
HYPERVISOR="AZURE"
IM_MAD=“az"
PRIORITY=”-1"
PUBLIC_CLOUD=“YES"
RESERVED_CPU=”“
RESERVED_MEM=”"
VM_MAD=“az”
WILD VIRTUAL MACHINES
NAME IMPORT_ID CPU MEMORY
VIRTUAL MACHINES
116 oneadmin oneadmin OpenNebula01 fail 0 0K NebulaND01 0d 00h21
I’ve downloaded the VHD image from “http://cloud-images.ubuntu.com/xenial/current/” (that’s why I can’t quite understand the “The virtual machine image source is not valid” error). And could load it into OpenNebula without a problem (just took a bit long, as it’s a 30GB image…):
This is the image template:
IMAGE 56 INFORMATION
USER : oneadmin
GROUP : oneadmin
DATASTORE : default
TYPE : OS
REGISTER TIME : 02/20 10:24:12
PERSISTENT : Yes
SOURCE : /var/lib/one//datastores/1/1883365189e91360ff1e39aae8e34e55
PATH : /var/tmp/xenial-server-cloudimg-amd64-disk1.vhd
FSTYPE : raw
STATE : used
RUNNING_VMS : 1
OWNER : um-
GROUP : —
OTHER : —
IMAGE TEMPLATE
DEV_PREFIX="vd"
DRIVER=“raw”
VIRTUAL MACHINES
116 oneadmin oneadmin OpenNebula01 fail 0 0K NebulaND01 0d 00h11
And this is the VM template…:
TEMPLATE 21 INFORMATION
NAME : Ubuntu 16.04 - Azure
USER : oneadmin
GROUP : oneadmin
REGISTER TIME : 02/14 15:38:46
OWNER : um-
GROUP : —
OTHER : —
TEMPLATE CONTENTS
CONTEXT=[
NETWORK=“YES”,
SSH_PUBLIC_KEY="ssh-rsa xxxxxxxxxxxxxxxxxxxxxx"
CPU="0.5"
CPU_COST="0.026"
DISK=[
IMAGE=“Ubuntu16.04-Azure”,
IMAGE_UNAME=“oneadmin” ]
DISK_COST="0.0000006"
FEATURES=[
ACPI=“yes”,
GUEST_AGENT=“yes”,
LOCALTIME=“yes” ]
GRAPHICS=[
LISTEN=“0.0.0.0”,
TYPE=“VNC” ]
HYPERVISOR=“kvm"
INPUTS_ORDER=”"
LOGO="images/logos/ubuntu.png"
MEMORY="1024"
MEMORY_COST="0.000014"
MEMORY_UNIT_COST="MB"
OS=[
ARCH=“x86_64”,
BOOT=“disk0” ]
PUBLIC_CLOUD=[
IMAGE=“Ubuntu 16.04 - COE”,
INSTANCE_TYPE=“Small”,
LOCATION=“West US 2”,
SSHPORT=“2222”,
TCP_ENDPOINTS=“80”,
TYPE=“AZURE”,
VM_PASSWORD=“xxxxxxxxx”,
VM_USER=“xxxxx”,
WIN_RM=“https” ]
SUNSTONE=[
NETWORK_SELECT=“NO” ]
USER_INPUTS=[
CPU=“O|fixed|| |0.5”,
MEMORY=“M|range||1024…16384|1024”,
VCPU=“O|range||1…16|1” ]
VCPU=“1”
Would anybody be able to point what I’m doing wrong? I’m quite sure it’s something very basic, but for the life of me, I just can’t figure that out…
This is OpenNebula 5.4.1 running on Ubuntu 16.04, by the way.
Thanks a lot,
Alex
