I have installed openenbula on a single system, everything works fine with it.
I had a little trouble with installing guacamole in docker, so I went ahead with a full guacamole install.
Ubuntu 22.04, Apache tomcat 9 , Guacamole 1.5.4, mariadb
I have the sql integration working fine and the servers running good.
I have the add connection and delete connection hooks configured and the usernames and passwords in the python scripts correctly configured. guacamole.properties is properly configured. Firewall rules are correct.
However when i provision and start the service . . .I get the following error and the connection is not reflected in Guacamole.
As you can see . .plenty of tries
And the error show by onehook show -e 14
This config is from my laptop, I have also installed this same on a proper server with lan ip addresses and the error remains the same, except for the url that reflects the real ip address and not the loopback.
I have added the http auth jar library to the gaucd extensions
That is pretty much it, except for I am up to about 40 tries on my main server
Any help would be greatly appreciated.
