Hello
I’m trying to deploy the simplest cluster with 2 host to test new OneStor native storage solution.
I’ve followed the official docs (OneStor Datastore — OpenNebula 6.0.4 documentation) but it seems that I’m missing something to make it works.
As a summary, this is the workflow:
- Install ONE 6.2 on first hosts with minione (one-01)
- Minione creates initial datastores (default: 0, system: 1 and files: 2)
- Add new host to the cluster (one-02)(KVM Node Installation — OpenNebula 6.0.4 documentation)
- Create aditional datastores needed by OneStor
- 100 system_replica_cluster
- 101 system_hosts_local
This is the final configuration:
ID NAME SIZE AVA CLUSTERS IMAGES TYPE DS TM STAT
101 system_hosts_local - - 0 0 sys - ssh on
100 system_replica_cluster - - 0 0 sys - ssh on
2 files 5.8T 95% 0 0 fil fs ssh on
1 default 5.8T 95% 0 1 img fs ssh on
0 system 5.8T 95% - 0 sys - qcow2 off
Datastore 1 is intended to be Image Datastore Replica (cache)
onedatastore show 1
DATASTORE 1 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : IMAGE
DS_MAD : fs
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/1
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 5.8T
FREE: : 5.5T
USED: : 420M
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
CLONE_TARGET="SYSTEM"
CLONE_TARGET_SSH="SYSTEM"
DISK_TYPE="FILE"
DISK_TYPE_SSH="FILE"
DRIVER="qcow2"
DS_MAD="fs"
LN_TARGET="SYSTEM"
LN_TARGET_SSH="SYSTEM"
SAFE_DIRS="/var/lib/one/import"
TM_MAD="ssh"
TM_MAD_SYSTEM="ssh"
TYPE="IMAGE_DS"
Datastore 100 is intended to be the one used for replication (keep snapshots). From doc: " Replication is enabled by the presence of the REPLICA_HOST key, with the name of one of the Hosts belonging to the cluster"
onedatastore show 100
DATASTORE 100 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : SYSTEM
DS_MAD : -
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/100
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : -
FREE: : -
USED: : -
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
DISK_TYPE="FILE"
DS_MIGRATE="YES"
REPLICA_HOST="one-02"
SHARED="NO"
TM_MAD="ssh"
TYPE="SYSTEM_DS"
Datastore 101 is intended to be the local datastore for each host to deploy local VMs
onedatastore show 101
DATASTORE 101 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : SYSTEM
DS_MAD : -
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/101
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : -
FREE: : -
USED: : -
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
DISK_TYPE="FILE"
DS_MIGRATE="YES"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
SHARED="NO"
TM_MAD="ssh"
TYPE="SYSTEM_DS"
With this setup, when I try to deploy a new VM is works fine, but the snapshoting mechanism for automatic recovery is not working.
Docs says that to enable automatic snapshot only need to add the option RECOVERY_SNAPSHOT_FREQ (300s in my test) to the vm disk section.
DISK = [
ALLOW_ORPHANS = "YES",
CLONE = "YES",
CLONE_TARGET = "SYSTEM",
CLUSTER_ID = "0",
DATASTORE = "default",
DATASTORE_ID = "1",
DEV_PREFIX = "vd",
DISK_ID = "0",
DISK_SNAPSHOT_TOTAL_SIZE = "0",
DISK_TYPE = "FILE",
DRIVER = "qcow2",
FORMAT = "qcow2",
IMAGE = "Alpine Linux 3.14",
IMAGE_ID = "0",
IMAGE_STATE = "2",
LN_TARGET = "SYSTEM",
ORIGINAL_SIZE = "256",
READONLY = "NO",
RECOVERY_SNAPSHOT_FREQ = "300",
SAVE = "NO",
SIZE = "256",
SOURCE = "/var/lib/one//datastores/1/fca60a0588a5374cb2f9361d20e98cb9",
TARGET = "vda",
TM_MAD = "ssh",
TYPE = "FILE" ]
The automation so that the snapshot is automatically launched and saved in the datastore (100 i guest) is not happening, and I don’t see anything in the logs that gives me any clues.
Going through the documentation, the configuration seems simple and I don’t find any additional step.
I would be grateful if any colleague could give me a clue because at the moment I have no more ideas.
Thanks a lot !!
