Hi
Did you know a way I use datastore type system and image using the disk of
nodes? By default OpenNebula takes the /var frontend, but I need to use
the disk nodes as datastore (using nfs or gluster).
Thank you.
Hi
Thank you.
You can find the storage documentation here:
http://docs.opennebula.org/4.14/administration/storage/sm.html
To use NFS, read about the shared option of the filesystem datastore:
http://docs.opennebula.org/4.14/administration/storage/fs_ds.html
For a distributed storage ceph is usually recommended; Gluster is not officially supported.
http://docs.opennebula.org/4.14/administration/storage/ceph_ds.html#ceph-ds
