I have two nodes with VLM full disk. I want use that VLMs how datastore for create my virtual machines. When I follow oficial documentation does not work.
My VG NAMES: openebula1-vg and opennebula2-vg.
IP front end: 10.5.0.1
IP node 1: 10.5.0.22
IP node 2: 10.5.0.27
hi Eduardo, I bet the lack of response is caused by the confusing message
I guess you mean LVM instead of VLM ?
And I guess you mean you want to use the local disks of the nodes as datastore?
If both assumptions are correct, then add them using those as SSH system datastore, see:
