I am using version 5.4.6 currently which have problem now where VDC admin is not allow to create its own Virtual Network.
Currently I have created a VDC which pre-allocate VNets as screen capture.
And created a Group with user admin inside.
This group is allow to use VDC resource.
Also created an ACL which I have already allow Group member to “use, manage,create, admin” - ID25
However, when login as VDC group admin. Create Virtual Networks still not allow.
Could you please advise how should solve this problem?
Thanks!
tinova
(Tino Vázquez)
February 2, 2018, 10:45am
2
You need to enable it in the Sunstone yamls. Take a look at file /etc/one/sunstone-views/groupadmin.yaml.
feldsam
(Kristian Feldsam)
February 3, 2018, 8:49am
3
Hi Tino, is it also possible to force VDC admin to create only specific type of network, eg 802.1q and preddefined physical interface?
Any details meaning for each parameters for groupadmin.yaml ?
I also read
[vdc-1]
[group_list]
[acl-1]
[acl-2]
However, when login as VDC group admin. Create Virtual Network…
but no much available information there.
Thanks!
tinova
(Tino Vázquez)
February 5, 2018, 2:46pm
5
That is currently not supported. Please open a feature request in GitHub to evaluate the use case.
jpfoures
(Jean-Philippe FOURES)
May 7, 2018, 1:53pm
6
I faced the same behavior on same release and before opening a Feature request I checked here if somelse faced the same.
I added some “admin” rights for the Admin user. I added an ACL with ADMIN right for “CLUSTERS”.
I am not a big fan of this workaround as it means that an external user with admin rights must be cluster administrator to create a Virtual Network. While for me this should not be the case (I will open a feature request for this).
@machiasiaweb , can you check if adding some admin rights to this user unlock you situation ?
Thank you
Regards
