How to disable option Groups in the "top-right drop-down" menu?
I’m think that it’s possible:
I want to remove option “Groups” from the “top-right drop-down” menu, аnd leaving it only enabled for selected users?
But I can’t to find this option in yaml files (sunstone-views)
menu_remove_group
Thank you.
Hello, I think that currently it’s not possible.
Hi!
Are there any changes on this issue?
Is it possible to make the user see only resources belonging to the user and any of his group and disable ALL
Hi @Max_Rybas
The dropdown menu shown in the first post of this thread cannot be hidden, however, that menu only shows the groups to which the user belongs.
A user should NOT be able to see resources that do not belong to him/her if the permissions have been configured correctly. I recommend you take a look at these sections of the documentation:
Best,
Victor.
