How can manage Azure VM by using OpenNebula portal.
I have Azure portal and I can create Azure VM however I would like to manage Azure VM from OpenNebula portal.
Please kindly share your experience.
Thanks
Hello @kyaw_swar_hein
It looks like you are looking to use the frontend interface. Have you checked our Documentation?:
https://docs.opennebula.io/6.6/quick_start/deployment_basics/try_opennebula_hosted.html
This other also could help you a bit:
https://docs.opennebula.io/6.6/quick_start/usage_basics/running_virtual_machines.html
In case that you got stuck at some point, let us know.
Regards,
Azure support was dropped on 6.0 when the cluster provisioning feature was released. Now there is no official integration for Azure cluster provisioning.
