I want to reset virtual machine back to original state. How to do that?
Hi @surya,
It depends on the configuration that you are using. If the VM disks are non-persistent you can use Recover -> Delete-recreate. This will delete the VM disks and recreate them from the source image. For VM with a persistent images you should restore the disk image from where you imported/cloned it.
Kind Regards,
