1072 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG I 31 Command execution fail: /var/lib/one/remotes/vmm/vmware/deploy ‘/var/lib/one/vms/31/deployment.0’ ‘ptnode02’ 31 ptnode02
1073
1074 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG E 31 deploy: Error executing: virsh -c ‘esx://ptnode02/?no_verify=1&auto_answer=1’ define /var/lib/one/vms/31/deployment.0 err: E xitCode: 1
1075
1076 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG I 31 out:
1077
1078 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG I 31 error: Failed to define domain from /var/lib/one/vms/31/deployment.0
1079
1080 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG I 31 error: internal error HTTP response code 404 for upload to 'https://ptnode02:443/folder/31%2Fdisk.0/one-31.vmx?dcPath=ha %2ddatacenter&dsName=0’
1081
1082 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG I 31
1083
1084 Thu Apr 2 19:55:43 2015 [VMM][D]: Message received: LOG I 31 ExitCode: 255
1085
It looks like the vmx file cannot be found. Can you confirm that in he host ptnode02 there is the following file:
/vmfs/volumes/<ds_id>/31/disk.0/one-31.vmx
where ds_id is the ID of the system datastore?
